Menu plug-in
Menu plug-in geertjan 01 Apr 13:10
  Menu plug-in Vincent Lordier 01 Apr 13:30
  Menu plug-in Michael Schumacher 01 Apr 13:39
   Menu plug-in geertjan 01 Apr 15:07
2009-04-01 13:10:54 UTC (about 16 years ago)
Menu plug-in
I am planning to develop a simple plug-in that will open a save dialog and open dialog that lets you open/save directly to/from a webdav disk.
I originally planned to incorporate this in the Menustructure of GIMP (under File), but I have some difficulties in finding an example of how to incorporate a new item in the GIMP menu structure..
Maybe it's my mistake, but if someone can give some pointers I would be very grateful, thanks.
Vincent Lordier
2009-04-01 13:30:41 UTC (about 16 years ago)
Menu plug-in
I doubt this would be really useful actually : wouldn't this kind of feature the responsibility of the OS ? If you mount a WebDAV disk in Gnome for instance, then it's available in the file open/save menu anyway ... same with Windows/OSX.
Geertjan
2009-04-01 13:39:01 UTC (about 16 years ago)
Menu plug-in
Von: "Geertjan"
I thought that this is supposed to be handled by GIO/GVFS (seomeone correct me if my impression is wrong). So I would expect that the existing open and save dialogs are capable of this already, although I've never tried this myself.
Does you plug-in do anything special?
2009-04-01 15:07:32 UTC (about 16 years ago)
Menu plug-in
Is GIO/GVFS also compatible with a plug-in for Gimp in combination with Windows? My intention is to make a cross platform plug-in.
Regards
