Gegl Developer's Document patch
Gegl Developer's Document patch Henrik Akesson 23 Mar 18:25
  Gegl Developer's Document patch Martin Nordholts 24 Mar 21:12
   Gegl Developer's Document patch Henrik Akesson 25 Mar 18:20
    Gegl Developer's Document patch Martin Nordholts 26 Mar 21:05
Henrik Akesson
2009-03-23 18:25:33 UTC (about 16 years ago)
I've started on a "Gegl Developer's Document". I'll let you be the judge if you want to add it to subversion already. It might be a good idea if others would like to add stuff as well. It also includes an autogenerated gobject inheritance diagram.
----------------------------------------------------------------- A first version of a "Gegl Developer's Document" * docs/development.txt
Linked new document with the main one * docs/index-static.txt.in
A ruby script that extracts the gobject inheritance diagram (going via graphviz) from the code.
* tools/gobj2dot.rb
Incorporated the generation of the diagram in the make, however it's slightly slow
* docs/Makefile.am
Added an example of the output generated by gegl-dot.c. * docs/images/gaussian-blur-graph.png -----------------------------------------------------------------
Any feedback is welcome
Henrik
Martin Nordholts
2009-03-24 21:12:06 UTC (about 16 years ago)
I think this is much nicer than nothing at all, and the inheritance tree gives a nice overview, so I would like to commit this. The patch does not pass 'make distcheck' however which needs to be addressed first. I will eventually do it, but it would be much appreciated if you could do it instead.
BR,
Martin
Henrik Akesson
2009-03-25 18:20:53 UTC (about 16 years ago)
Fixed !
2009/3/24 Martin Nordholts :
BR,
Martin
Martin Nordholts
2009-03-26 21:05:18 UTC (about 16 years ago)
Fixed !
Thanks, commited:
2009-03-26 Martin Nordholts
Apply patch from Henrik Akesson that adds initial how-to-hack-on-GEGL documentation, including a ruby script to generate a graphviz graph of the class inheritance trees in the core.
* docs/Makefile.am * docs/development.txt
* docs/images/gaussian-blur-graph.png * docs/index-static.txt.in
* tools/gobj2dot.rb
