making html pages for an easier updatable site
making html pages for an easier updatable site Marco Ciampa 23 Mar 15:05
  making html pages for an easier updatable site Ulf-D. Ehlert 24 Mar 21:34
   making html pages for an easier updatable site Marco Ciampa 25 Mar 10:55
    making html pages for an easier updatable site Ulf-D. Ehlert 25 Mar 14:02
     making html pages for an easier updatable site Marco Ciampa 25 Mar 20:54
      making html pages for an easier updatable site Ulf-D. Ehlert 26 Mar 13:11
Marco Ciampa
2009-03-23 15:05:49 UTC (about 16 years ago)
Since more eyeballs make bugs popup easier than only two, I am trying to use user generated html pages for a local, more quickly updated, site.
Doing
make
creates a html pages & update images links but...in a way that (IMHO) is not really smart.
One example is better than a thouthands words... Essentially, for italian and english, the output of the command is:
html/en html/it
these two dirs contains all the html code with one image simlink that points to ../../xml/en/images and ../../xml/it/images respectively.
so we have:
html/en html/it
xml/en/images
xml/it/images
This is all ok but...in xml/en/images (and similarly in xml/it/images) there are _not_ images but _absolute_ simbolic links to
for example:
xml/it/images/dialogs/scale-image.png
points to
-> /home/marco/svn-gnome/gimp-help-2/trunk/images/it/dialogs/scale-image.png
this makes copying this stuff to a site not so fast...
Q: is it possible to substitute all absolute links with relative one or (alternatively) making only one absolute reference (that is easier to modify) and all other references relative to this one?
TIA
Ulf-D. Ehlert
2009-03-24 21:34:40 UTC (about 16 years ago)
Marco Ciampa (Montag, 23. März 2009, 15:05):
for example:
points to
Yes, this was just the easiest way to create these links - because I didn't know the command to convert absolute links to relative links. (It seems there is no such command.)
Yes, of course. For instance, we can write a little shell/Perl/Python script to make relative links or (better) to do all the find-image-and-make-link stuff (try 'make -n xml/it/images' to see these commands).
No, we "copy" the image files in xml/it/images from two different sources: the English (language-independent) images or the localized images. So IMO we had to use three absolute references (to images/C, images/common, images/LANG)...
Ulf
Marco Ciampa
2009-03-25 10:55:20 UTC (about 16 years ago)
for example:
points to
apt-get install symlinks
man symlinks
ok I'm working on it, please wait...
ok right I agree...
bye
Ulf-D. Ehlert
2009-03-25 14:02:23 UTC (about 16 years ago)
Marco Ciampa (Mittwoch, 25. März 2009, 10:55):
man symlinks
That's it!
But is seems to be Debian-specific... :-(
Don't write a script based on "symlinks"!
I've written a little Perl script, which uses the File:.Spec module and should be portable.
Check it, it should be what you need.
Ulf
Marco Ciampa
2009-03-25 20:54:25 UTC (about 16 years ago)
Done, it works.
I've done this little silly script to automate the html creation process:
(if it isn't too simple we could add it to the tools dir or insert it in the makefile)
make-gimp-manual-html
#!/bin/bash
# Creates the html pages archive
# to be run after a 'make html'
#change your path accordingly SRCBASE=~/svn-gnome/gimp-help-2/trunk
cd /tmp mkdir gimp-manual
mkdir gimp-manual/images
cd gimp-manual
cp -R ${SRCBASE}/html html
for i in `ls ${SRCBASE}/html` ; do rm html/${i}/images
echo "copying ${i} html files..."
cp -R ${SRCBASE}/xml/${i}/images html/${i}/images if [ "$i" = "en" ]; then
j="C"
else
j=$i
fi
echo "copying ${j} image files..." cp -R ${SRCBASE}/images/${j} images/${j} find images/${j} -name '.svn' | xargs rm -Rf done
echo "copying common image files..." cp -R ${SRCBASE}/images/common images/common rm -Rf images/common/.svn
echo "copying callouts image files..." cp -R ${SRCBASE}/images/callouts images/callouts rm -Rf images/callouts/.svn
echo "creating archive..."
tar cf gimp-manual.tar *
echo "compressing..."
gzip gimp-manual.tar
mv gimp-manual.tar.gz ~
cd ..
echo "removing data dirs..."
rm -Rf gimp-manual
echo "done."
With your patch and this script, updating the site pages should be strightforward.
I'll use these for creating and updating a local mirror of docs.gimp.org/en & docs.gimp.org/it.
I've tested your script and it works. I think that you shoould commit it and update the automake.am too.
bye
Ulf-D. Ehlert
2009-03-26 13:11:29 UTC (about 16 years ago)
Marco Ciampa (Mittwoch, 25. März 2009, 20:54):
The (autotools generated) Makefile contains some dist* targets, and there is also the old (disabled) install target ("install-data-local") in Makefile.am. I didn't check them, but it may be that they are meant to build the html packages...
If that's true, you should consider making these install routines work with the new build system rather than (or in addition to) adding this script.
Bye,
Ulf
