Gimp crashes
Gimp crashes adivawoman 21 Mar 18:52
  Gimp crashes adivawoman 21 Mar 19:04
  Gimp crashes Michalis Giokas 21 Mar 22:25
2009-03-21 18:52:19 UTC (about 16 years ago)
Gimp crashes
I think I am posting this in the right place Ihave searched the forms and faqs but I am getting now where is finding a solution to my problem.
Gimp crashes and freezes bad. I have the latest version. I read that too many brushes can cause this so I only use the brushes that came with it and when I need a new brush I install it then remove it when I am done. I have not added plug ins or new script foo things. I am using only the basics.
I defag, check for errors, clean registory, clean cache, remove temp files, etc., all the stuff I read to do.
Image size, layer amount, what tool or filter etc., makes no difference. I get about 5-15 minutes of work time then freeze. I save like heck. So for about ever 15 minutes of work time it takes me about 20 minutes of freeze.
Here are some snapshots of my system to give more information That I uploaded. MY computer is a HP dual core. http://i652.photobucket.com/albums/uu246/adivawoman/msconfig.jpg
2009-03-21 19:04:08 UTC (about 16 years ago)
Gimp crashes
I didnt do this right none of my http screen shots loaded.
Michalis Giokas
2009-03-21 22:25:52 UTC (about 16 years ago)
Gimp crashes
yes mary....i ve noticed that too....
especially if the custom brush s scale is too big
(if the brush margin exceeds the image or the layer then all bad thinks can happen :)...)
