Problem compiling buffer tests
Problem compiling buffer tests Henrik Akesson 18 Mar 19:27
  Problem compiling buffer tests Martin Nordholts 18 Mar 20:43
   Problem compiling buffer tests Henrik Akesson 19 Mar 12:00
Henrik Akesson
2009-03-18 19:27:56 UTC (about 16 years ago)
I get a lot of errors when compiling and trying to run the gegl/tests/buffer (output from "make check" below). Everything else works ok. Would you have any idea of why?
Thanks,
Henrik
At first it was complaining about not finding the "gegl.pc" when running "make check":
--------------------------------------------------------------------------- Package gegl was not found in the pkg-config search path. Perhaps you should add the directory containing `gegl.pc' to the PKG_CONFIG_PATH environment variable ---------------------------------------------------------------------------------------------------------
So I set it: ------------------------------------------------------------------------------------ echo $PKG_CONFIG_PATH
/home/hakesson/Dev/gegl-dev/
echo $GEGL_PATH /home/hakesson/Dev/gegl-dev/operations/ ------------------------------------------------------------------------------------
Output of "make check": ----------------------------------------------------------------------------------------------------------------------------------------------------------------- gcc -g -Wall buffer-test.c -o buffer-test `pkg-config gegl --cflags --libs` gcc: $(top_builddir)//home/hakesson/Dev/gegl-dev/gegl/libgegl.la: No such file or directory
buffer-test.c:1:18: error: gegl.h: No such file or directory buffer-test.c:2:25: error: gegl-buffer.h: No such file or directory In file included from ../../gegl/buffer/gegl-buffer-iterator.h:23, from buffer-test.c:15: ../../gegl/buffer/gegl-buffer.h:23:23: error: babl/babl.h: No such file or directory
In file included from ../../gegl/buffer/gegl-buffer-iterator.h:23, from buffer-test.c:15: ../../gegl/buffer/gegl-buffer.h:55: warning: type defaults to ‘int’ in declaration of ‘GeglRectangle’
../../gegl/buffer/gegl-buffer.h:55: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
../../gegl/buffer/gegl-buffer.h:82: warning: type defaults to ‘int’ in declaration of ‘GeglRectangle’
../../gegl/buffer/gegl-buffer.h:82: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
../../gegl/buffer/gegl-buffer.h:114: warning: type defaults to ‘int’ in declaration of ‘GeglRectangle’
../../gegl/buffer/gegl-buffer.h:114: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
../../gegl/buffer/gegl-buffer.h:134: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
../../gegl/buffer/gegl-buffer.h:149: warning: type defaults to ‘int’ in declaration of ‘GeglRectangle’
../../gegl/buffer/gegl-buffer.h:149: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
../../gegl/buffer/gegl-buffer.h:217: warning: type defaults to ‘int’ in declaration of ‘GeglRectangle’
----------------------------------------------------------------------------------------------------------------------------------------------------------------- snip....
Full output in attached buffer_make.txt.zip
Martin Nordholts
2009-03-18 20:43:26 UTC (about 16 years ago)
IIRC some buffer test Makefile contains a hardcoded path to /usr/local, did you change that?
BR,
Martin
Henrik Akesson
2009-03-19 12:00:17 UTC (about 16 years ago)
Found a solution:
have to do a "sudo make install" of gegl before running the tests. I assume that is for installing the included header files into /usr/local/include/gegl-0.0.
Henrik
2009/3/18 Martin Nordholts
BR,
Martin
