Brush scale adjustment for smudge tool is currently broken
Brush scale adjustment for smudge tool is currently broken David Gowers 09 Mar 00:43
David Gowers
2009-03-09 00:43:04 UTC (almost 16 years ago)
Hello!
I have just been trying to get into Bugzilla, to mention this in the 'rotate brushes' bug, but Bugzilla is currently hanging for all operations.
Anyway, suppose you have a brush of radius 16, and you set brush scale to 0.25 and begin smudging. The smudge is performed with the original sized brush mask (ie, still 16 radius). Nor does the angle adjustment have any effect.
It's also somewhat baffling that Clone doesn't support dynamic brush angle. I guess this is because of different routines to apply paint between normal tools like paintbrush and more obscure ones like clone/heal.
Complete list of tools that don't support angle dynamics, though it makes sense for them to:
Dodge/Burn Heal
Clone + perspective-clone
Convolve
Technically, it also makes sense for Smudge to support (this would make smudge a lot nicer for mouse users), that would be quite involved though ( as you'd need to rotate the smudge accumulation buffer as well as the brush mask.)
David
