Default tags for GIMP resources
Default tags for GIMP resources Aurimas Juška 28 Feb 22:43
Aurimas Juška
2009-02-28 22:43:50 UTC (about 16 years ago)
As you might already know, GIMP from next version will allow to tag resources (brushes, patterns, etc). It would be nice to create a default tag set for resources provided in a standard GIMP distribution. If someone would like to volunteer, there are following options to create (possibly partial) tag set:
* (easier) edit tags from GUI or tags.xml (found in $HOME/.gimp-2.7/tags.xml) file directly and send the tags.xml file to me and I could take care of updating the necessary files in source tree.
* (harder) edit gimp/data/tags/gimp-tags-default.xml.in directly. File structure is pretty simple and each entry should look similar to this (s are already generated, only s need to be added):
test1
test2
test3
If you have any questions, feel free to ask.
Best regards, Aurimas
