babl portability patches, and a test failure
It is very difficult to compile babl-0.0.22 unless you are using gcc and gmake with the GNU coreutils and ruby, on a linux host.
With the attached patches I was able to successfully build everything with the vendor compilers, and pass all but one test (failure output below) on these 30 architectures:
SuSE SLES 10 (x86_64 and i686);
Redhat RHEL3, RHEL4 and RHEL5 (x86_64 and i686);
Redhat 7.1, 9 and RHEL 2.1 (i686);
Solaris 10 (x86 and sparc);
Solaris 2.6, 7, 8 and 9 (sparc);
AIX 4.3.3, 5.1, 5.2, 5.3 and 6.1 (powerpc);
HPUX 11.31 (ia64);
HPUX 11.23 (pa-risc and ia64);
HPUX 10.20, 11.0 and 11.11 (pa-risc);
IRIX 6.5 (mips);
Tru64 Unix 5.1 (ev5).
Here is a list of some of the problems solved by the attached patches, which would otherwise prevent proper compilation by one or more vendor C compilers:
* build the extensions with libtool
* support '.sl' shared library ext on HPUX
* use correct includedir entry in babl.pc
* use gnulib stdint.h for systems that don't have one
* support shl_load -ldl library loader on HPUX
* remove extraneous trailing commas from *CONVERSION mcros
* automake INCLUDES is deprecated, use AM_CPPFLAGS
* support srcdir != builddir builds
* use automake source file inference in tests/
* pregenerate changelog.rss (ruby is not commonly installed)
* don't double #include
* variadic macros are not portable
* don't use non-constant struct initializers
* don't use the MSB of a signed integer type in an enum
* don't use C++ comments
* rewrite xml_instert.sh not to rely on GNU coreutils
* for gnulib and autoconf to work properly, every .c file
needs to #include before anything else!
I also wrapped the body of BABL_DETECT_CFLAGS in a GCC test, since some vendor compilers simply warn and ignore unknown flags. It would be better to fix this properly.
Correct compilation on Tru64 relies on use of the -ieee flag to cc, which I passed manually. It would be better to detect this at configure time with a correctly implemented BABL_DETECT_CFLAGS macro.
I regenerated the autotools files with latest released versions of autoconf, automake and libtool which results in a huge diff, not attached!
I also removed the babl-0.0 include subdirectory and some other instances of the @API-VERSION@, which are superflous for our installations (each package already installs to /opt/fsw/@pkg@-@version@/), but is almost certainly the wrong thing to do in upstream releases.
With these patches applied, all hosts (except linux) always fail the final test case. I'm not sure whether this is an anticipated rounding error that the test itself should be tolerant of, or if there is a genuine problem with all of the non-linux builds?
PASS: grayscale_to_rgb
PASS: rgb_to_bgr
PASS: rgb_to_ycbcr
PASS: srgb_to_lab_u8
PASS: sanity
PASS: babl_class_name
PASS: types
R'G'B'
test: 60323.989 75673.805 55655.807 10508.764
clipped: 60324.000 75673.819 55655.817 1.000
trnsfrmd: 60324.010 75673.832 55655.827 1.000
R'G'B'
test: 22002.791 20097.686 55166.163 25341.894
clipped: 22002.794 20097.689 55166.173 1.000
trnsfrmd: 22002.798 20097.693 55166.182 1.000
R'G'B'
test: 31145.225 44052.134 43954.156 9807.322
clipped: 31145.230 44052.142 43954.163 1.000
trnsfrmd: 31145.235 44052.149 43954.171 1.000
R'G'B'
test: 21854.712 45827.089 6242.623 90425.124
clipped: 21854.716 45827.097 6242.624 1.000
trnsfrmd: 21854.719 45827.105 6242.624 1.000
R'G'B' is not symmetric
R'G'B'A
clipped: 60324.000 75673.819 55655.817 10508.764
trnsfrmd: 60324.010 75673.832 55655.827 10508.764
R'G'B'A
clipped: 22002.794 20097.689 55166.173 25341.894
trnsfrmd: 22002.798 20097.693 55166.182 25341.894
R'G'B'A
clipped: 31145.230 44052.142 43954.163 9807.322
trnsfrmd: 31145.235 44052.149 43954.171 9807.322
R'G'B'A
clipped: 21854.716 45827.097 6242.624 90425.124
trnsfrmd: 21854.719 45827.105 6242.624 90425.124
R'G'B'A is not symmetric
R'aG'aB'aA
R'aG'aB'aA
R'aG'aB'aA
R'aG'aB'aA
R'aG'aB'aA is not symmetric
Y'
clipped: 68802.171 68802.171 68802.171 1.000
trnsfrmd: 68802.183 68802.183 68802.183 1.000
Y'
clipped: 24665.123 24665.123 24665.123 1.000
trnsfrmd: 24665.127 24665.127 24665.127 1.000
Y'
clipped: 40181.806 40181.806 40181.806 1.000
trnsfrmd: 40181.813 40181.813 40181.813 1.000
Y'
clipped: 34146.725 34146.725 34146.725 1.000
trnsfrmd: 34146.731 34146.731 34146.731 1.000
Y' is not symmetric
Y'A
clipped: 68802.171 68802.171 68802.171 10508.764
trnsfrmd: 68802.183 68802.183 68802.183 10508.764
Y'A
clipped: 24665.123 24665.123 24665.123 25341.894
trnsfrmd: 24665.127 24665.127 24665.127 25341.894
Y'A
clipped: 40181.806 40181.806 40181.806 9807.322
trnsfrmd: 40181.813 40181.813 40181.813 9807.322
Y'A
clipped: 34146.725 34146.725 34146.725 90425.124
trnsfrmd: 34146.731 34146.731 34146.731 90425.124
Y'A is not symmetric
Y'aA
Y'aA
Y'aA
Y'aA
Y'aA is not symmetric
Y'CbCr
clipped: 60323.989 75673.855 55655.819 1.000
trnsfrmd: 60323.988 75673.904 55655.832 1.000
Y'CbCr
clipped: 22002.810 20097.691 55166.172 1.000
trnsfrmd: 22002.829 20097.696 55166.181 1.000
Y'CbCr
clipped: 31145.230 44052.178 43954.166 1.000
trnsfrmd: 31145.235 44052.222 43954.176 1.000
Y'CbCr
clipped: 21854.693 45827.155 6242.625 1.000
trnsfrmd: 21854.673 45827.221 6242.628 1.000
Y'CbCr is not symmetric
Y'CbCrA
clipped: 60323.989 75673.855 55655.819 10508.764
trnsfrmd: 60323.988 75673.904 55655.832 10508.764
Y'CbCrA
clipped: 22002.810 20097.691 55166.172 25341.894
trnsfrmd: 22002.829 20097.696 55166.181 25341.894
Y'CbCrA
clipped: 31145.230 44052.178 43954.166 9807.322
trnsfrmd: 31145.235 44052.222 43954.176 9807.322
Y'CbCrA
clipped: 21854.693 45827.155 6242.625 90425.124
trnsfrmd: 21854.673 45827.221 6242.628 90425.124
Y'CbCrA is not symmetric
FAIL: models
1 of 8 tests failed
If I can provide clarification for the necessity of any of the changes I made, or if a complete tarball with patches preapplied would be useful, or if you would like me to test a prerelease version with some of these fixes already applied, please don't hesitate to ask.
Thanks for your work on BABL and GEGL!
Cheers, Gary
SuSE SLES 10 (x86_64 and i686); Redhat RHEL3, RHEL4 and RHEL5 (x86_64 and i686); Redhat 7.1, 9 and RHEL 2.1 (i686); Solaris 10 (x86 and sparc);
AIX 4.3.3, 5.1, 5.2, 5.3 and 6.1 (powerpc); HPUX 11.31 (ia64);
HPUX 10.20, 11.0 and 11.11 (pa-risc); IRIX 6.5 (mips);
Nice work. But unfortunately that i a huge pile of changes in more or less one large patch. You don't happen to be able to provide this as a changeset broken up into smaller changes? Some of the changes are definitely good, but we might want to handle a few things differently.
I think that is IMO a good idea even though it will increase build time significantly.
As a result you made the babl_log() macro a lot more difficult to use. IMO we should rather add a test for variadic macros to the configure script (this can be copied from glib's configure.in) and then define babl_log() similar to what GLib does in gmessages.h:
#ifdef G_HAVE_ISO_VARARGS
#define g_message(...) g_log (G_LOG_DOMAIN, \
G_LOG_LEVEL_MESSAGE, \
__VA_ARGS__)
#else if defined(G_HAVE_GNUC_VARARGS)
#define g_message(format...) g_log (G_LOG_DOMAIN, \
format)
#else
g_message (const gchar *format,
va_list args;
va_start (args, format);
g_logv (G_LOG_DOMAIN, G_LOG_LEVEL_MESSAGE, format, args);
va_end (args);
#endif
That is OK. But I saw that your patch removes comments in some places. That is not OK, they should be converted to /* ... */ comments instead.
* for gnulib and autoconf to work properly, every .c file needs to #include before anything else!
Yes, definitely!
On Mon, Feb 23, 2009 at 11:27:14PM +0100, Sven Neumann wrote:
Hi Sven,
Tru64 Unix 5.1 (ev5).Nice work. But unfortunately that i a huge pile of changes in more or less one large patch. You don't happen to be able to provide this as a changeset broken up into smaller changes? Some of the changes are definitely good, but we might want to handle a few things differently.
We have a system for maintaining platform patches under standard names in quilt for each package we build, which is unfortunately optimised to make best use of our time when it comes to porting the changes forward to new upstream releases... and less useful for passing patches back to developers :(
I'm sorry I don't have time to create a series of individual self- contained changesets, though I'd be happy to run prereleases through our build system, and resubmit the patches necessary for successful compilation on our machines.
Also, libtool is able to build the extensions on many of the hosts above that were not supported by the existing Makefile rules.
#ifdef G_HAVE_ISO_VARARGS #define g_message(...) g_log (G_LOG_DOMAIN, \ G_LOG_LEVEL_MESSAGE, \ __VA_ARGS__) #else if defined(G_HAVE_GNUC_VARARGS) #define g_message(format...) g_log (G_LOG_DOMAIN, \ G_LOG_LEVEL_MESSAGE, \ format) #else
va_list args;
g_logv (G_LOG_DOMAIN, G_LOG_LEVEL_MESSAGE, format, args); va_end (args);
#endif
Most definitely. I simply made the fastest changes I could for successful compilation. I'm sure there are technically better means to implement several of the changes I made! :)
Agreed. That was laziness on my part. Sorry.
Yes, definitely!
And I even kept that in a separate patch! :)
Cheers, Gary
Yes, definitely!
I have committed that part to trunk now. Actually, I changed it to include "config.h" as that's more correct than . After all we are not including a system header here but a local one.
attached is a patch for babl_log. I am not too happy with the outcome as it will result in less informative log output on platforms that don't support variadic macros. But I guess that's somewhat hard to avoid and hopefully the most important platforms will support this feature. I'd appreciate feedback on this patch.
Index: babl/babl-internal.h
--- babl/babl-internal.h (revision 394)
+++ babl/babl-internal.h (working copy)
@@ -122,7 +122,7 @@ int babl_type_is_symmetric
/* FIXME: nasty,. including the symbol even in files where it is
* not needed,. and a dummy function to use it in those cases
-static BablDb *db=NULL;
+static BablDb *db = NULL;
static void hack_hack (void)
if (db==NULL)
@@ -135,26 +135,27 @@ static void hack_hack (void)
void babl_backtrack (void);
static inline void
-real_babl_log (const char *file,
- int line,
- const char *function,
- const char *fmt, ...)
+real_babl_logv (const char *file,
+ int line,
+ const char *function,
+ const char *fmt,
+ va_list varg)
- Babl *extender = babl_extender();
- va_list varg;
- if (extender != babl_extension_quiet_log())
+ if (file && function)
- if (babl_extender())
- fprintf (stdout, "When loading %s:\n\t", babl_extender()->instance.name);
+ Babl *extender = babl_extender();
- fprintf (stdout, "%s:%i %s()\n\t", file, line, function);
+ if (extender != babl_extension_quiet_log())
+ if (babl_extender())
+ fprintf (stdout, "When loading %s:\n\t",
+ babl_extender()->instance.name);
+ fprintf (stdout, "%s:%i %s()\n\t", file, line, function);
- va_start (varg, fmt);
vfprintf (stdout, fmt, varg);
- va_end (varg);
fprintf (stdout, "\n");
fflush (NULL);
@@ -162,14 +163,67 @@ real_babl_log (const char *file,
hack_hack ();
-#define babl_log(args...) \
+static inline void
+real_babl_log (const char *file,
+ int line,
+ const char *fmt,
+ va_list varg;
+ va_start (varg, fmt);
+ real_babl_logv (file, line, function, fmt, varg);
+ va_end (varg);
+#ifdef HAVE_ISO_C_VARARGS
+#define babl_log(...) \
+ real_babl_log(__FILE__, __LINE__, __func__, __VA_ARGS__)
+#define babl_fatal(...) do{ \
+ real_babl_log(__FILE__, __LINE__, __func__, __VA_ARGS__); \
+ babl_die();} \
+while(0)
+#elif if defined(HAVE_GNUC_VARARGS)
+#define babl_log(args...) \
real_babl_log(__FILE__, __LINE__, __func__, args)
-#define babl_fatal(args...) do{ \
- real_babl_log(__FILE__, __LINE__, __func__, args);\
- babl_die();} \
+#define babl_fatal(args...) do{ \
+ real_babl_log(__FILE__, __LINE__, __func__, args); \
+ babl_die();} \
while(0)
+#else /* no varargs macros */
+static void
+babl_log (const char *fmt,
+ va_list args;
+ va_start (args, fmt);
+ real_babl_logv (NULL, 0, NULL, fmt, args);
+ va_end (args);
+static void
+babl_fatal (const char *fmt,
+ va_list args;
+ va_end (args);
+ babl_die();
+#endif
#define babl_assert(expr) do{ \
if(!(expr)) \
Index: configure.ac
--- configure.ac (revision 393)
+++ configure.ac (working copy)
@@ -132,12 +132,46 @@ BABL_DETECT_CFLAGS(extra_warnings, '-Wol
CFLAGS="$CFLAGS $extra_warnings"
+# Check for flavours of varargs macros
+AC_MSG_CHECKING(for ISO C99 varargs macros in C)
+AC_TRY_COMPILE([],[
+int a(int p1, int p2, int p3);
+#define call_a(...) a(1,__VA_ARGS__)
+call_a(2,3);
+], have_iso_c_varargs=yes, have_iso_c_varargs=no)
+AC_MSG_RESULT($have_iso_c_varargs)
+if test "x$have_iso_c_varargs" = "xyes"; then
+ AC_DEFINE(HAVE_ISO_C_VARARGS, 1,
+ [Define to 1 if the compiler supports ISO C99 variadic macros])
+fi
+AC_MSG_CHECKING(for GNUC varargs macros)
+#define call_a(params...) a(1,params)
+call_a(2,3);
+], have_gnuc_varargs=yes, have_gnuc_varargs=no)
+AC_MSG_RESULT($g_have_gnuc_varargs)
+if test "x$have_gnuc_varargs" = "xyes"; then
+ AC_DEFINE(HAVE_GNUC_VARARGS, 1,
+ [Define to 1 if the compiler supports GNUC variadic macros])
+fi
+# Check availability of programs
AC_PATH_PROG(INKSCAPE, inkscape, no)
AM_CONDITIONAL(HAVE_INKSCAPE, test "x$INKSCAPE" != "xno")
AC_PATH_PROG(W3M, w3m, no)
AM_CONDITIONAL(HAVE_W3M, test "x$W3M" != "xno")
# Check target architecture
Hi Sven,
Thanks for following up on this.
I also ported glibs variadic macro detection into babl, and gegl, while splitting up my original sumo-patch to port forward to the SVN HEAD(s). Unfortunately, it still doesn't work quite right on our older machines as is, but I'll upload the fully ported and tested version (along with my other patches) to GNOME's bugzilla after the weekend.
Please consider waiting until you've seen that patch before you commit anything.
Cheers,
Gary
Hi Sven,
Yes, definitely!
In this case, that's not the best thing to do (witness the contents of gnulib as an example). Here's the relevant reasoning from the autoconf info manual:
To provide for VPATH builds, remember to pass the C compiler a `-I.' option (or `-I..'; whichever directory contains `config.h'). Even if you use `#include "config.h"', the preprocessor searches only the directory of the currently read file, i.e., the source directory, not the build directory.
With the appropriate `-I' option, you can use `#include '. Actually, it's a good habit to use it, because in the rare case when the source directory contains another `config.h', the build directory should be searched first.
I actually tripped over that very error while testing srcdir!=builddir
(aka VPATH) builds with my patches.
Cheers,
Gary
I actually tripped over that very error while testing srcdir!=builddir (aka VPATH) builds with my patches.
Sorry, but that's how GIMP and other projects have been doing it for more than a decade and there have never been any problems with that approach. If there is -I$(top_srcdir) missing in the INCLUDES in some babl Makefile, please let us know and we will add it.
If the source directory actually contains another 'config.h' then you should hunt down the programmer who added it there and shoot him.
Gary, I exptected some feedback, but didn't hear from you. Are you not any longer interested to get the babl portability problems solved?
Hi Sven,
Sorry, I've been offline for the last week (moving from Thailand to New Zealand).
I've split apart my patches, and ported them to today's git master branch, and am in the process of uploading them to bugzilla.gnome.org.
Cheers, Gary
Hi Sven,
Has anyone been able to find time to look at my patch queue for babl?
http://bugzilla.gnome.org/show_bug.cgi?id=574705
I've also uploaded a similar patch queue for gegl itself, though I'm still unable to get it working on 2 of the 30 architectures we support:
http://bugzilla.gnome.org/show_bug.cgi?id=576615
If there's anything else I should do to help shepherd these patches into the trunk, please let me know.
Cheers, Gary
I will look at them asap
- Martin
Awsome :) Many thanks.
Cheers, Gary
Cheers, Gary
Hi
I've updated the babl and GEGL bug reports now with status on what patches that have been commited and where I am currently stuck
- Martin
Hi Martin,
Excellent, thanks for that. I will have time to look at that early next week... and I'll post on this thread when I'm done.
Cheers, Gary
Hi Martin,
Actually, the changes required for everything to apply cleanly to git master were trivial for both babl and GEGL, so I've uploaded all the updated patches to bugzilla again already (as attachments to the original bug reports):
http://bugzilla.gnome.org/show_bug.cgi?id=574705 http://bugzilla.gnome.org/show_bug.cgi?id=576615
I still have one consistent test failure on all non-linux hosts with babl+my_patches, and SEGV in the testsuite for GEGL+my_patches on RH Linux 7.1 and OSF/5.1... but I'll post about those separately next week.
Cheers,
Gary
I've done another round of commiting and this time I bumped into problems when applying the prepare-for-gnulib patch, bot for babl and GEGL.
Could you look into that please? Info is in the bug reports. I suspect it will be pretty straightforward to fix for the author of the patch.
BR, Martin
Hi Martin,
Awesome! Thanks again :)
I've explained how to make that work at bugzilla.
No worries... also attached a couple more GEGL portability patches needed for the newest changes to git master.
Cheers, Gary
Hi Martin,
I thought I'd give an update on this (in case you didn't receive the bugzilla mail).
The only thing I can see missing now is taking care of invoking gnulib-tool
--update properly in autogen.sh and provide a helpful message why this
fails,
if it fails.
Is there any de facto standard way of doing this?
- Martin
Hi Martin,
On Sun, Apr 05, 2009 at 05:09:50PM +0200, Martin Nordholts wrote:
The only thing I can see missing now is taking care of invoking gnulib-tool --update properly in autogen.sh and provide a helpful message why this fails, if it fails.
No, there isn't.
Worse, there's a good argument for committing gnulib files to the repository so that churn in the upstream gnulib repository doesn't foil testing of client projects where several developers ran gnulib-tool from different versions of gnulib. There's also the issue of how to keep track of which gnulib version contributed to released client software.
You ought to come up with a policy decision for how gnulib will be employed in babl and GEGL before implementing the process. There is a list of projects that already use gnulib here:
http://git.savannah.gnu.org/gitweb/?p=gnulib.git;a=blob_plain;f=users.txt;hb=HEAD
You could look at some of these for inspiration for how other projects have integrated gnulib code into their repositories. In my (biased) humble opinion, GNU M4 integrates the gnulib tree into it's git repository in a neat and easy to manage way.
Cheers, Gary
Hi Martin,
The M4 way [1] indeed looks very nice and maintainable, could you provide a patch for that approach please?
- Martin
[1] http://git.savannah.gnu.org/gitweb/?p=m4.git;a=commitdiff;h=33434cee444ebefb51734ec286857e7639500ad3
Oh, and we most likely want to wait with this until the GNOME migration to git, which will begin April 16, is complete.
- Martin
Hi Gary
The git migration is now complete, how is your patch coming along?
As a starting point for Git for developers, refer to this site: http://live.gnome.org/Git/Developer
BR, Martin
actually
http://live.gnome.org/Git/Developers
, FYI :)
actually
http://live.gnome.org/Git/Developers , FYI :)
Oops, yes, thanks for correcting that
- Martin
