Problem compiling gegl
Problem compiling gegl Berkut 23 Feb 16:35
  Problem compiling gegl Henrik Akesson 23 Feb 16:46
  Problem compiling gegl Martin Nordholts 23 Feb 17:39
  Problem compiling gegl Sven Neumann 23 Feb 21:10
Problem compiling gegl Berkut 23 Feb 20:09
Berkut
2009-02-23 16:35:11 UTC (about 16 years ago)
I've got the latest bebl and gegl from the svn repos, and successfully built and installed bebl, but when I try and make gegl, I get the following error:
--[Updating sample compositions]-- ../clones.xml
** Message: Module '../../operations/core/.libs/convert-format.so' load error: ../../operations/core/.libs/convert-format.so: undefined symbol: babl_format_get_bytes_per_pixel ** Message: Module '../../operations/external/.libs/save-pixbuf.so' load error: ../../operations/external/.libs/save-pixbuf.so: undefined symbol: babl_format_has_alpha
** Message: Module '../../operations/external/.libs/png-save.so' load error: ../../operations/external/.libs/png-save.so: undefined symbol: babl_format_get_type
** (lt-gegl:22536): WARNING **: Failed to set operation type gegl:png-save, using a passthrough op instead /home/peter/Documents/apps/gegl/bin/.libs/lt-gegl: symbol lookup error: /home/peter/Documents/apps/gegl/gegl/.libs/libgegl-0.0.so.0: undefined symbol: babl_format_get_bytes_per_pixel make[5]: *** [clones.png] Error 127
../OpenRaster-00.xml
** (lt-gegl:22568): WARNING **: Failed to set operation type gegl:png-save, using a passthrough op instead /home/peter/Documents/apps/gegl/bin/.libs/lt-gegl: symbol lookup error: /home/peter/Documents/apps/gegl/gegl/.libs/libgegl-0.0.so.0: undefined symbol: babl_format_get_bytes_per_pixel make[5]: *** [OpenRaster-00.png] Error 127 ../OpenRaster-01.xml
** (lt-gegl:22595): WARNING **: Failed to set operation type gegl:png-save, using a passthrough op instead /home/peter/Documents/apps/gegl/bin/.libs/lt-gegl: symbol lookup error: /home/peter/Documents/apps/gegl/gegl/.libs/libgegl-0.0.so.0: undefined symbol: babl_format_get_bytes_per_pixel make[5]: *** [OpenRaster-01.png] Error 127 ../OpenRaster-04.xml
** (lt-gegl:22622): WARNING **: Failed to set operation type gegl:png-save, using a passthrough op instead /home/peter/Documents/apps/gegl/bin/.libs/lt-gegl: symbol lookup error: /home/peter/Documents/apps/gegl/gegl/.libs/libgegl-0.0.so.0: undefined symbol: babl_format_get_bytes_per_pixel make[5]: *** [OpenRaster-04.png] Error 127 make[4]: *** [images.stamp] Error 2
make[4]: Leaving directory `/home/peter/Documents/apps/gegl/docs/gallery' make[3]: *** [all-recursive] Error 1 make[3]: Leaving directory `/home/peter/Documents/apps/gegl/docs/gallery' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/home/peter/Documents/apps/gegl/docs' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/peter/Documents/apps/gegl' make: *** [all] Error 2
Are the two in sync yet, or does more work need to be done?
Thanks, Berkut
Henrik Akesson
2009-02-23 16:46:47 UTC (about 16 years ago)
Did you set BABL_LIBS when configuring gegl?
I.e: ./autogen.sh BABL_LIBS=~/Dev/babl/.libs/
/Henrik
2009/2/23 Berkut
Thanks, Berkut
Martin Nordholts
2009-02-23 17:39:27 UTC (about 16 years ago)
Hi
SVN trunk of babl and GEGL should be completely compatible without problems, your problem looks like an install issue.
In particular I suspect that GEGL did not pickup the SVN trunk version of babl but an old systemwide installation of babl. Be sure to se PKG_CONFIG_PATH when you configure (autogen.sh) GEGL.
- Martin
Berkut
2009-02-23 20:09:23 UTC (about 16 years ago)
----- Original Message -----
To: Berkut
Cc: gegl-developer@lists.xcf.berkeley.edu Subject: Re: [Gegl-developer] Problem compiling gegl Date: Mon, 23 Feb 2009 16:46:47 +0100
I.e:
/Henrik
I didn't, but I've tried it again with that, and unfortunately it makes no difference.
Thanks, Berkut
2009-02-23 21:10:51 UTC (about 16 years ago)
If you just updated your tree, you might have objects in your tree that remained from a previous build. Or you might have such installed in the GEGL search path. The errors you pasted are not compilation problems, but problems to build the documentation. This can in most cases be fixed easily by removing all previously installed gegl modules and by using a fresh SVN checkout.
