Documenting gegl
Documenting gegl Henrik Akesson 19 Feb 18:47
  Documenting gegl Nicolas Robidoux 19 Feb 19:04
  Documenting gegl Martin Nordholts 20 Feb 07:51
Henrik Akesson
2009-02-19 18:47:23 UTC (about 16 years ago)
Documenting gegl
Hi all,
I'm learning gegl internals for doing some work on parallelizing it (I've posted before on that subject). When I do it I normally write some documentation of my own (when it's missing), such as:
http://computerresearcher.blogspot.com/search/label/Gegl
Note that it's fragmented and still under construction.
Instead of writing it on my blog I could contribute it.
1. Are you interested in that?
If yes:
2. What is the appropriate format. Asciidoc? Note that there are/will be images, documentation for specific c files and general documentation.
3. It would need to be reviewed. I'm after all learning this stuff... How can it be done practically. I suppose that a separate svn branch for me with someone of you merging could be a solution.
/Henrik
Nicolas Robidoux
2009-02-19 19:04:43 UTC (about 16 years ago)
Documenting gegl
Hello Henrik:
I don't know if this was mentioned before, but the open source VIPS
http://www.vips.ecs.soton.ac.uk/index.php?title=VIPS
although quite different to GEGL, is also somewhat similar.
VIPS handles CMPs well.
Maybe some of VIPS' under the hood parallel machinery would carry over?
Nicolas Robidoux
Laurentian University/Universite Laurentienne
Martin Nordholts
2009-02-20 07:51:12 UTC (about 16 years ago)
Documenting gegl
Henrik Akesson wrote:
I normally write some documentation of my own (when it's missing) Instead of writing it on my blog I could contribute it.
Absolutely, and the best way to get the documentation into GEGL is to write patches which add this documentation to the source code. I think the best way for you to do this is to clone the git repository (which is a mirroring of the SVN repository) according to the instructions here:
http://live.gnome.org/GitForGnomeDevelopers
and do your work in git. The workflow on that page is a bit weird but you'll figure out a better one. The only thing that took some time for me to figure out is that when you get error messages when you do a
git svn rebase
that is about non-synced revisions, just do
rm .git/svn/origin/svn/trunk/.rev_map.f648641c-e325-0410-9857-ab48a05b167d
to force a reconstruction of the revision map. When you're done you can just export a patch that you send to the list or attach to bugzilla.
BR, Martin
