pygegl make fails
pygegl make fails Scott Gorlin 19 Feb 17:03
  pygegl make fails Hubert Figuiere 19 Feb 17:31
   pygegl make fails Scott Gorlin 19 Feb 17:53
Scott Gorlin
2009-02-19 17:03:53 UTC (about 16 years ago)
pygegl make fails
I'm trying to build the python bindings without much success. babl and gegl are successfully installed from svn, but I get the error below when making pygegl. I'm running Ubuntu 8.10 w/ python 2.5 on a dell latitude d620. Any suggestions?
Thanks, Scott
nlinfit:~/scripts> svn co http://svn.gnome.org/svn/gegl/trunk/bindings/pygegl pygegl A pygegl/configure.ac
A pygegl/COPYING.LESSER
A pygegl/samples
A pygegl/samples/op-reference.py
A pygegl/samples/subgraph.py
A pygegl/samples/render-test.py
A pygegl/samples/.gitignore
A pygegl/samples/xml-parsing.py
A pygegl/samples/Makefile.am
A pygegl/.gitignore
A pygegl/AUTHORS
A pygegl/acinclude.m4
A pygegl/ChangeLog
A pygegl/COPYING
A pygegl/Makefile.am
A pygegl/autogen.sh
A pygegl/NEWS
A pygegl/README
A pygegl/Gegl
A pygegl/Gegl/fifthleg.py
A pygegl/Gegl/geglrectangle.override A pygegl/Gegl/.gitignore
A pygegl/Gegl/geglmodule.c
A pygegl/Gegl/__init__.py
A pygegl/Gegl/Makefile.am
A pygegl/Gegl/gegl.override
A pygegl/Gegl/gegl.defs
U pygegl
Checked out revision 2920.
nlinfit:~/scripts> cd ./pygegl/
nlinfit:~/scripts/pygegl> ./autogen.sh
I am testing that you have the tools required to build the pygegl project from SVN. This test is not foolproof, so if anything goes wrong, see the file HACKING for more information...
checking for libtool >= 1.4 ... Major version might be too new (2.2.4) checking for autoconf >= 2.54 ... yes (version 2.61) checking for automake >= 1.8.3 ... yes (version 1.10.1)
I am going to run ./configure with the following arguments:
--enable-maintainer-mode
If you wish to pass additional arguments, please specify them on the ./autogen.sh command line or set the AUTOGEN_CONFIGURE_ARGS environment variable.
libtoolize: putting auxiliary files in `.'. libtoolize: linking file `./ltmain.sh' libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.ac and libtoolize: rerunning libtoolize, to keep the correct libtool macros in-tree. libtoolize: Consider adding `-I m4' to ACLOCAL_AMFLAGS in Makefile.am. configure.ac:74: installing `./config.guess' configure.ac:74: installing `./config.sub' configure.ac:31: installing `./install-sh' configure.ac:31: installing `./missing' Gegl/Makefile.am: installing `./depcomp' Gegl/Makefile.am:6: installing `./py-compile' Makefile.am: installing `./INSTALL'
Running ./configure...
checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... gawk
checking whether make sets $(MAKE)... yes checking for gcc... gcc
checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking for style of include used by make... GNU checking dependency style of gcc... gcc3 checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking for a sed that does not truncate output... /bin/sed checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B checking the name lister (/usr/bin/nm -B) interface... BSD nm checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864 checking whether the shell understands some XSI constructs... yes checking whether the shell understands "+="... yes checking for /usr/bin/ld option to reload object files... -r checking how to recognize dependent libraries... pass_all checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok checking how to run the C preprocessor... gcc -E checking for ANSI C header files... yes checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC -DPIC checking if gcc PIC flag -fPIC -DPIC works... yes checking if gcc static flag -static works... yes checking if gcc supports -c -o file.o... yes checking if gcc supports -c -o file.o... (cached) yes checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... no checking whether to enable maintainer-specific portions of Makefiles... yes checking for target architecture... i686-pc-linux-gnu checking for native Win32... no
checking for library containing strerror... none required checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes checking whether gcc accepts -g... (cached) yes checking for gcc option to accept ISO C89... (cached) none needed checking dependency style of gcc... (cached) gcc3 checking for a BSD-compatible install... /usr/bin/install -c checking whether make sets $(MAKE)... (cached) yes checking for a Python interpreter with version >= 2.4.0... python checking for python... /usr/bin/python checking for python version... 2.5
checking for python platform... linux2 checking for python script directory... ${prefix}/lib/python2.5/site-packages checking for python extension module directory... ${exec_prefix}/lib/python2.5/site-packages checking for headers required to compile python extensions... found checking for pkg-config... /usr/bin/pkg-config checking pkg-config is at least version 0.9.0... yes checking for PYGOBJECT... yes
checking for pygtk-codegen-2.0... /usr/bin/pygtk-codegen-2.0 checking whether gcc understands -fno-strict-aliasing... yes checking for GEGL... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating Gegl/Makefile config.status: creating samples/Makefile config.status: creating config.h
config.status: executing depfiles commands config.status: executing libtool commands
Now type 'make' to compile the pygegl project. nlinfit:~/scripts/pygegl> make
make all-recursive
make[1]: Entering directory `/home/scott/scripts/pygegl' Making all in Gegl
make[2]: Entering directory `/home/scott/scripts/pygegl/Gegl' /bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/python2.5 -I/usr/include/pygtk-2.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/local/include/gegl-0.0 -I/usr/local/include/babl-0.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -fno-strict-aliasing -g -O2 -MT geglmodule.lo -MD -MP -MF .deps/geglmodule.Tpo -c -o geglmodule.lo geglmodule.c libtool: compile: gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/python2.5 -I/usr/include/pygtk-2.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/local/include/gegl-0.0 -I/usr/local/include/babl-0.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -fno-strict-aliasing -g -O2 -MT geglmodule.lo -MD -MP -MF .deps/geglmodule.Tpo -c geglmodule.c -fPIC -DPIC -o .libs/geglmodule.o mv -f .deps/geglmodule.Tpo .deps/geglmodule.Plo (cd . \
&& /usr/bin/pygtk-codegen-2.0 \
--py_ssize_t-clean \
--override gegl.override \
--prefix pygegl gegl.defs) > gen-gegl.c \ && cp gen-gegl.c gegl.c \
&& rm -f gen-gegl.c
note: pygtk-codegen-2.0 is deprecated, use pygobject-codegen-2.0 instead note: I will now try to invoke pygobject-codegen-2.0 in the same directory ***INFO*** The coverage of global functions is 100.00% (4/4) ***INFO*** The coverage of methods is 100.00% (34/34) ***INFO*** There are no declared virtual proxies. ***INFO*** There are no declared virtual accessors. ***INFO*** There are no declared interface proxies. /bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/python2.5 -I/usr/include/pygtk-2.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/local/include/gegl-0.0 -I/usr/local/include/babl-0.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -fno-strict-aliasing -g -O2 -MT gegl.lo -MD -MP -MF .deps/gegl.Tpo -c -o gegl.lo gegl.c libtool: compile: gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/python2.5 -I/usr/include/pygtk-2.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/local/include/gegl-0.0 -I/usr/local/include/babl-0.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -fno-strict-aliasing -g -O2 -MT gegl.lo -MD -MP -MF .deps/gegl.Tpo -c gegl.c -fPIC -DPIC -o .libs/gegl.o gegl.override: In function ‘_wrap_gegl_color_get_rgba’: gegl.override:132: warning: passing argument 2 of ‘gegl_color_get_rgba’ from incompatible pointer type gegl.override:132: warning: passing argument 3 of ‘gegl_color_get_rgba’ from incompatible pointer type gegl.override:132: warning: passing argument 4 of ‘gegl_color_get_rgba’ from incompatible pointer type gegl.override:132: warning: passing argument 5 of ‘gegl_color_get_rgba’ from incompatible pointer type gegl.override: In function ‘_wrap_gegl_node_render’: gegl.override:495: error: dereferencing pointer to incomplete type make[2]: *** [gegl.lo] Error 1
make[2]: Leaving directory `/home/scott/scripts/pygegl/Gegl' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/scott/scripts/pygegl' make: *** [all] Error 2
Hubert Figuiere
2009-02-19 17:31:59 UTC (about 16 years ago)
pygegl make fails
Are you sure the python bindings are up to date with the API changes in trunk?
Hub
Scott Gorlin
2009-02-19 17:53:32 UTC (about 16 years ago)
pygegl make fails
Personally, I have no idea :)
I did get them to compile when I just had the default Ubuntu installation of gegl, which I think was version 0.18. But none of the python examples were working for me, kept getting errors like 'function has no attribute x' for any argument passed into a gegl function, so I figured Ubuntu was just out of date and I installed direct from SVN.
Is there anywhere it says what version the python bindings are designed for? Or anyone know if/when they will be updated? I couldn't find any info, and last commit looks like it was in November
-Scott
