"quit" signal for plugins
8 of 8 messages available
"quit" signal for plugins Glimmer Labs 30 Jan 21:33
  "quit" signal for plugins Bill Skaggs 01 Feb 18:16
  "quit" signal for plugins Sven Neumann 01 Feb 19:49
   "quit" signal for plugins Glimmer Labs 03 Feb 17:27
    "quit" signal for plugins Sven Neumann 03 Feb 19:47
     "quit" signal for plugins Glimmer Labs 04 Feb 15:12
      "quit" signal for plugins Sven Neumann 05 Feb 22:12
       "quit" signal for plugins Glimmer Labs 10 Feb 15:44
Glimmer Labs
2009-01-30 21:33:37 UTC (about 16 years ago)
I have been developing a plugin that involves users editing files and I need to be able to prompt them to save when the gimp closes.
I have tried using the quit signal in pluginInfo:
GimpPlugInInfo PLUG_IN_INFO = {
NULL,
quit,
query,
run
This only seems to be called, however, when the plugin closes and not the gimp.
(It is a GTK plugin with it's own window like script-fu, I get the signal when I close the plugin window, but if the user closes the gimp I have no way to clean up.)
Is this a bug or is my understanding of what this callback is supposed to do flawed?
Is there another way to do what I am trying to accomplish?
Thank you for your time, Soren Berg
Bill Skaggs
2009-02-01 18:16:54 UTC (about 16 years ago)
I don't think there is any way to do this using current functionality. Communication
between GIMP and its plug-ins is controlled by the plug-ins -- there is no way to
send a signal from GIMP to a plug-in. When GIMP shuts down while a plug-in is running, the only thing that tells the plug-in about it is the fact that the "wire" --
the shared memory channel used for communication -- stops functioning. That's why you typically see a "wire read error" message in this situation.
-- Bill
2009-02-01 19:49:22 UTC (about 16 years ago)
NULL,
quit,
query,
run
The latter. The quit function is called by libgimp whenever the plug-in quits, not when GIMP quits. This is not very useful, but that is how it was designed a long time ago.
I am not entirely sure how plug-ins are quit by the core when the GIMP core exits. It would probably make sense to make sure that the plug-in's quit function is called. On the other hand we don't want the application to hang there waiting for plug-ins to quit. If you want to investigate this further, we could try to help you to fix this issue.
Glimmer Labs
2009-02-03 17:27:32 UTC (about 16 years ago)
I have been thinking about this and it does seem to be a somewhat thorny issue.
One possible solution would be to call the quit functions of the plugins but have a timeout set
so that you could pop up a dialog if they did not quit after a second or two asking if the user wanted
to terminate the plugin. But this seems messy.
Another thought:
If a plugin has a quit function that hangs or takes a long time, won't that affect the gimp when
the quit function is normally called (on closing of plugin)? If so, the gimp is already exposed to the problem of poorly written plugins, and it might as well call the quit functions of active plugins when it exits.
Or does the gimp have some way of protecting against this issue that wouldn't work if it was closing?
Thank you for your assistance, -Soren Berg
2009-02-03 19:47:55 UTC (about 16 years ago)
I very much doubt that any real-world plug-in is actually using the quit function. I tried to use it once in a patch attached to http://bugzilla.gnome.org/show_bug.cgi?id=8141#c7
Glimmer Labs
2009-02-04 15:12:46 UTC (about 16 years ago)
Thank you for the link to that thread, it was very informative.
I have yet to find any sort of workaround. I tried trapping all the TERM type signals but no luck there.
Is doing a non blocking wait still under discussion? Actually, for my purposes it doesn't matter whether the wait is blocking, because I just need to
run a gedit style "Save changes?" dialog. Or, if I only had a second, just save some sort of backup.
It seems like several different plugins could take advantage of that because they make temporary images.
(or would this still be only on plugin quit and not gimp quit?)
Thanks again for your continued assistance, -Soren Berg
2009-02-05 22:12:00 UTC (about 16 years ago)
I think it would make sense to call the quit method in all running plug-ins when the core is quit. So a patch that does this would be much appreciated. We need to somehow deal with the problem of hanging plug-ins though.
Glimmer Labs
2009-02-10 15:44:47 UTC (about 16 years ago)
I can code up a patch if we can figure out how to prevent stalling.
My approach would be to fork and call the quit method in the child, then if the child doesn't return in two seconds, pop up a dialog informing the user that a plug in is not responding and give them the option to terminate it.
I don't know how the GIMP deals with threading though, so I'm not sure that that is appropriate in this case.
Someone earlier mentioned a non-blocking wait, does the GIMP have some system in place for doing that?
