making html
making html julien 29 Jan 21:50
  making html Ulf-D. Ehlert 29 Jan 23:55
   making html julien 30 Jan 08:09
julien
2009-01-29 21:50:26 UTC (about 16 years ago)
making html
I ran
make -f Makefile.GNU html-fr
and got
[XML] xml/fr/menus/file/open-location.xml po/fr/menus/file.po:1800: « msgid » and « msgstr » strings don't end both with « \n »
msgfmt: 1 fatal error found
-:1: parser error : Document is empty ^
-:1: parser error : Start tag expected, '?). There is no error in open-location.xml.
More, the html file for open-location is created normally! (html created after deleting the html/fr folder).
Do I must ignore this fatal error?
Julien
Ulf-D. Ehlert
2009-01-29 23:55:04 UTC (about 16 years ago)
making html
julien (Donnerstag, 29. Januar 2009, 21:50):
Don't know what this error message means, but did you check line 1800?
More, the html file for open-location is created normally! (html created after deleting the html/fr folder). Do I must ignore this fatal error?
No, you should never ignore fatal errors.
Bye, Ulf
julien
2009-01-30 08:09:18 UTC (about 16 years ago)
making html
Thank you. Problem is resolved.
I was looking for a missing '\n'. It was an unwanted one at the end of the msgstr of 'translator credits"!
Julien
