gimp-help-2: New From Visible (julien)
1 of 2 messages available
mailman.5.1233086405.12249.... 07 Oct 20:27
  gimp-help-2: New From Visible (julien) Alchemie foto\\grafiche 28 Jan 13:33
2009-01-28 13:33:36 UTC (about 16 years ago)
I understand better.
"What is visible" is really a flattenned stack of the visible layers (with an eye in the Layer dialog).
Not exactly flattened but merged
Flatten will a remove the alpha channel, replacing any transparent area with the background color
The question is the interest of this command. Alexia, please, could you detail your example?
well i can not reply for Alexia but i may give a example.
On a hypothetic image add a duplicate layer on top in Overlay mode give me excellent result to enhance details and contrast on some area But terrible result on others
On the other hand a similar process but in Multiply mode will do the opposite ,improving that part (i.e under-saturated and too pale sky and clouds)that overlay mode will screw up ,but worsening the rest,
with NEW from visible i may save, and then merge the best of both combination easily
apply new from visible for combination-1,(overlay) toggle off visibility of that new layer, repeat the process to save result of combination-2(multiply)
then i may erase with more on less opacity what i do not like on the New merged top layer and when happy of the combination , save
you will not able to get the same using "merge visible layers" once merged will become impossible to recombine the layers in a different mode,
You may not need that feature
But if you would need it , without NEW from visible,you would need to get trough 5 no too much intuitive steps instead then a single click
