Advanced Interpolation
11 of 11 messages available
Advanced Interpolation jungle 24 Jan 05:18
  Advanced Interpolation David Gowers 24 Jan 14:17
   Advanced Interpolation David Gowers 24 Jan 14:21
   Advanced Interpolation jcupitt@gmail.com 24 Jan 17:59
    Advanced Interpolation Nicolas Robidoux 24 Jan 18:32
     Advanced Interpolation Nicolas Robidoux 24 Jan 19:47
      Advanced Interpolation jungle 24 Jan 23:11
       Advanced Interpolation Nicolas Robidoux 25 Jan 01:11
        Advanced Interpolation Nicolas Robidoux 25 Jan 01:23
         Advanced Interpolation Nicolas Robidoux 25 Jan 01:26
          Advanced Interpolation Nicolas Robidoux 28 Jan 06:43
jungle
2009-01-24 05:18:02 UTC (about 16 years ago)
Has anyone ever done any work implementing advanced interpolation schemes (NEDI or ICBI)? They provide much better results than the spatially invariant schemes present in GIMP.
I would probably be able to code up something, but I wouldn't be able to guarantee that it would be very efficient. Of course, these more complicated methods are much slower.
ICBI matlab GPL source is available. I should be able to port it to c++. What do y'all think?
Bill
David Gowers
2009-01-24 14:17:43 UTC (about 16 years ago)
AFAIK no.
NEDI looks amazing, and ICBI even more amazing; I could certainly put them to good use rather than my current rather slow/limited vectorization-based scaling system.
Keep in mind:
a) You should investigate implementing this interpolation method for GEGL rather than GIMP, as in the fairly near future these kinds of transformations in GIMP will be implemented through use of GEGL. b) If you want it included with the baseline GEGL distribution, it would need to be written not in C++ but in C. If you don't, then you can probably code it in C++ fine.
David
David Gowers
2009-01-24 14:21:23 UTC (about 16 years ago)
AFAIK no.
Keep in mind:
To clarify -- this is because both GEGL and GIMP are written in C.
David
jcupitt@gmail.com
2009-01-24 17:59:32 UTC (about 16 years ago)
2009/1/24 David Gowers :
My understanding is that this will not be possible in GEGL as things stand, since GEGL does not give interpolators the local slopes. In other words, a GEGL interpolator is just asked for the value at (double x, double y), it can't find out how closely spaced the surrounding sample points are.
No doubt this could be added or changed. I think other interpolator authors have been asking for this feature as well.
John
Nicolas Robidoux
2009-01-24 18:32:09 UTC (about 16 years ago)
John, David and Bill:
jcupitt@gmail.com writes: > 2009/1/24 David Gowers :
> > a) You should investigate implementing this interpolation method for > > GEGL rather than GIMP, as in the fairly near future these kinds of > > transformations in GIMP will be implemented through use of GEGL. >
> My understanding is that this will not be possible in GEGL as things > stand, since GEGL does not give interpolators the local slopes. In > other words, a GEGL interpolator is just asked for the value at > (double x, double y), it can't find out how closely spaced the > surrounding sample points are.
> No doubt this could be added or changed. I think other interpolator > authors have been asking for this feature as well. >
> John
Nicolas Robidoux
2009-01-24 19:47:30 UTC (about 16 years ago)
Bill:
There are already two fast nonlinear resamplers implemented in GEGL:
YAFR (gegl-sampler-yafr.c)
and
Nohalo-sharp (gegl-sampler-sharp.c).
Both are a little slower than gegl-sampler-linear, but faster than gegl-sampler-bicubic. See the (informal) benchmarks at
http://bugzilla.gnome.org/show_bug.cgi?id=566717
Code wise, you may want to have a look at the following:
http://svn.gnome.org/viewvc/gegl/trunk/gegl/buffer/gegl-sampler-sharp.c?revision=2881&view=markup
This is the lowest quality/fastest version of a scheme which, at higher quality levels, should compete advantageously will NEDI in the good looks department.
Nohalo-sharp is (literally as we speak!) also being implemented in vips, and on the GPU (with DirectX).
A not yet implemented variant of the scheme, Nohalo-Smooth, will look smoother (duh!).
YAFR (Yet Another Fast Resampler) is likely to be made obsolete by the higher level nohalos.
See:
http://svn.gnome.org/viewvc/gegl/trunk/gegl/buffer/gegl-sampler-yafr.c?view=markup
I'd love manpower (GSoC?) to implement Nohalo-Smooth and/or either Nohalo at higher quality levels.
(Just a wish.)
Nicolas Robidoux Laurentian University/Universite Laurentienne
jungle
2009-01-24 23:11:39 UTC (about 16 years ago)
and
I'm not familiar with those two resamplers. Of course, that's not saying much, because it's not my area of expertise. I should mention, however, that I consider NEDI and ICBI interpolators of a different kind than most.
First of all, they are very slow compared to bicubic. Speed is not the goal.
Secondly, they don't provide a value for any point in between given pixels. Rather, their purpose is to enlarge the image in question by a factor of 2 (roughly. Actually it's size*2-1). After scaling, the image can be resampled to any size desired using other methods. Both algorithms copy known (given) pixel values into a 2x enlarged grid and then fill in the gaps between pixels using certain assumptions about the statistical values of the pixels.
The main benefit of both algorithms is the performance around edges. ICBI is an improvement on NEDI. Edges are much smoother and more natural than bicubic.
Basically, these would be useful for creating high-quality scaled versions of images where you can leave them to work for a while. For instance, I tried to run ICBI (in an inefficient matlab implementation) on a 3072x2304 image, and I ended up stopping it after about 30 mins.
I would expect a C implementation to be much faster (especially because it wouldn't thrash the HD as much, since it would be designed with the purpose in mind instead of using general purpose functions).
I explain all this to try to decide if the goal of ICBI is different than nohalo, and if there would be a reason to try to code it. Is there a paper I can read on nohalo? Or examples of results that I could compare to ICBI?
Bill
Nicolas Robidoux
2009-01-25 01:11:18 UTC (about 16 years ago)
Hello Bill:
At some point it may a good idea to move this discussion off the list, but at this point I'll hope that those without interest in these issues are just skipping this email.
jungle writes: >
> > There are already two fast nonlinear resamplers implemented in GEGL: > >
> > and
> > Nohalo-sharp (gegl-sampler-sharp.c). > >
> I'm not familiar with those two resamplers. Of course, that's not saying > much, because it's not my area of expertise. I should mention, however, > that I consider NEDI and ICBI interpolators of a different kind than most. >
> First of all, they are very slow compared to bicubic. Speed is not the > goal.
> Secondly, they don't provide a value for any point in between given pixels. > Rather, their purpose is to enlarge the image in question by a factor of 2 > (roughly. Actually it's size*2-1). After scaling, the image can be > resampled to any size desired using other methods. Both algorithms copy > known (given) pixel values into a 2x enlarged grid and then fill in the gaps > between pixels using certain assumptions about the statistical values of the > pixels.
> The main benefit of both algorithms is the performance around edges. ICBI > is an improvement on NEDI. Edges are much smoother and more natural than > bicubic.
This is how nohalo works too, The current (low quality, but highly optimized) gegl-sampler-sharp.c only subdivides once and uses bilinear as "finishing scheme."
Consquently, the gegl-sampler-sharp.c code may provide a good basis for an implementation of "single subdivision" NEDI or ICBI, "one level implementations" which should give good results for resamplings which only involve moderate enlargement/stretching ratios (for nohalo, it's up to about 3-6).
> I explain all this to try to decide if the goal of ICBI is > different than nohalo, and if there would be a reason to try to > code it. Is there a paper I can read on nohalo? Or examples of > results that I could compare to ICBI?
Nohalo-sharp and nohalo-smooth are brand new schemes (we hope: maybe we'll find that they actually are "old"; I have to confess that I don't know as much about them as I should). We are currently writing the first paper about them. But there should be two comparison web sites coming up "soon."
You can also install the current gegl svn trunk and do the testing yourself. I'll include a sample .xml file at the end of this email (adapted from something Øyvind Kolås passed on).
My hunch is that, given the same subdivision level, nohalo will not "straighten" as much as NEDI/ICBI, but will show less "fine scale artifacts" and will run faster---even if programmed with the same programming skill.
This being said, if you would contribute toward the programming effort involved in implementing the "higher level nohalos" (I would guess the main programming issues are basically the same as with implementing the higher subdivisions for NEDI and ICBI) I'd be happy to count you among the co-authors of the appropriate paper(s).
If you just end up programming NEDI/ICBI---but don't touch nohalo---I'd be happy to use your code for our image resizing comparison suite (which should be on the web fairly soon).
Nicolas Robidoux Universite Laurentienne/Laurentian University
Nicolas Robidoux
2009-01-25 01:23:46 UTC (about 16 years ago)
Bill:
I forgot the sample xml code to test nohalo-sharp level 1:
How to use:
Step 1:
Put this in a file (called, say, scale16p4PICTURE.xml) in the directory
YOUR_GEGL_ROOT/docs/gallery/
YOUR_GEGL_ROOT being where you installed the gegl svn trunk.
For example, if you used
svn co http://svn.gnome.org/svn/gegl/trunk/ gegl
then YOUR_GEGL_ROOT is gegl.
Step 2:
Put PICTURE.png in
YOUR_GEGL_ROOT/docs/gallery/data
Step 3:
In YOUR_GEGL_ROOT/docs/gallery/
do
make clean && make
Step 4:
Point your browser to
(Note: you may want to rm -i *.xml in gallery to remove the xml drivers which don't interest you.)
nicolas
Nicolas Robidoux
2009-01-25 01:26:14 UTC (about 16 years ago)
Apologies:
I meant:
YOUR_GEGL_ROOT/docs/gallery/index.html
Nicolas Robidoux
2009-01-28 06:43:29 UTC (about 16 years ago)
Bill:
A quick note about gegl-sampler-sharp (a.k.a. nohalo-bilinear level 1): I just checked, and it does a pretty good job at mild downsampling.
Also:
I am not convinced, far from it actually, that NEDI will do better than nohalo level 1 when the enlargement ratio is moderate (no larger than about 3), and I am pretty confident that higher level nohalos will actually do better across the board. It almost certainly will be much slower.
So: I am not sure it really is worth your while implementing them for GEGL, given that their aims are pretty much the same, and the means are not completely different..
(Warning: I am highly biased: I am the main designer of the nohalo method. I also stand to be corrected: nohalo is still too young for me to really know its character. Note that nohalo-bilinear level 1 used on a CG picture which is "writing like"---as opposed to a photograph of a natural scene---is >>not<< likely to give impressive results.)
