<placeholder> problem
<placeholder> problem julien 21 Jan 15:26
  <placeholder> problem Ulf-D. Ehlert 21 Jan 20:23
julien
2009-01-21 15:26:24 UTC (almost 17 years ago)
In src/menus/view-navigwindow.xml, I deleted the "para" about access through Ctrl-E and I changed the guiicon fileref to "images/C/using/stock-navigation-16.png".
Then I ran "make pot" and make -f Makefile.GNU update-po/fr/menus/view-navigwindow.po
The Ctrl-E para has been removed in my view-window.po: OK But the guiicon fileref is replaced with .
How do I can get rid of that?
Julien
Ulf-D. Ehlert
2009-01-21 20:23:23 UTC (almost 17 years ago)
julien (Mittwoch, 21. Januar 2009, 15:26):
The fileref should read "images/using/stock-navigation-16.png":
find xml/fr/images -name '*stock-navigation*'
You can't.
Ok, that's not true...
'xml2po' replaces (and etc.) tags always with tags. These tags seems to be quite useful, and they don't represent text.
The only way to get rid of them is to customize (patch) the xml2po program. For example, I have tried a simple patch to rename some of the placeholder tags to make the text more readable (figure-placeholder, guiicon-placeholder, etc.). Another patch tried to force 'xml2po' to output those nodes (if I remember correctly, this didn't work for nodes without content, though). But using the default xml2po program we can't do anything here.
Bye,
Ulf
