R: Gimp-developer Digest, Vol 76, Issue 21
1 of 2 messages available
mailman.236385.1231924908.1... 07 Oct 20:27
  R: Gimp-developer Digest, Vol 76, Issue 21 Alchemie foto\\grafiche 14 Jan 13:33
2009-01-14 13:33:05 UTC (over 16 years ago)
I stopped reading here. Please describe your level of knowledge in Script-Fu before you do continue in this thread.
Maybe what has to be described is the concept of "same", maybe you give to the word "same" a sense to me a bit peculiar but technically much more correct then mine
Using "glossy logo.scm" From File /create Logo i see 1 GUI, if i call the same £glossy.logo.scm" from Filter/Alpha to Logo i see a very different GUI The 2 GUI of the "same " glossy.scm script different for the option they offer i.e from GUI 2 are removed option to chose font and text for my Logo...no way to access to that option.
But you are right better stop with words i may clear my proposal much better with few images then with words
Even if i know a bit of script fu i am much more a artist then a developer so i may explain much better the point with visual examples,
So i will took 2 screenshoots to the 2 different GUI of the "same" glossy.scm script. And i will add a mock up of the ideal "glossy.scm" GUI
Not sure if i will also able to edit the glossy.scm" for give a even more clear example, should be not too hard add a text selector and a option to export the output on a new imagine to the Filter/Alpha to Logo/glossy script...but this would take me much more time then a mockup
