images
9 of 9 messages available
images Ulf-D. Ehlert 12 Jan 18:55
  images Marco Ciampa 12 Jan 21:08
  images julien 13 Jan 07:19
   images Ulf-D. Ehlert 13 Jan 14:07
    images julien 13 Jan 15:03
     images Ulf-D. Ehlert 13 Jan 19:11
      images Ulf-D. Ehlert 14 Jan 19:47
       images julien 15 Jan 09:43
        images Ulf-D. Ehlert 15 Jan 18:28
Ulf-D. Ehlert
2009-01-12 18:55:44 UTC (almost 17 years ago)
images
I have added changes to use localized images. But committing failed somehow (with a message like "committing successful, there are errors").
Then svn revert and svn cleanup failed too...
It seems that some files are committed, though.
Any ideas what happened and what I can do?
Ulf
Marco Ciampa
2009-01-12 21:08:36 UTC (almost 17 years ago)
images
Ulf
I made an update without errors ... are you shure that something went really wrong or it is only you are afraid of having done something bad? Could you describe the committing errors?
julien
2009-01-13 07:19:42 UTC (almost 17 years ago)
images
All seems to be right after svn update...
I need some more explanations. Example: src/menus/selection-border.xml In this file we have
fileref="images/dialogs/selection-border.png"
I suppose that 'make' will add /C/, /de/, /fr/... automatically according to the selected language.
But we have also fileref="images/dialogs/examples/border-selection-02.png", that is an image common to all languages. There, /C/, /de/, /fr/... must not be added.
How will 'make' manage this? Must we move this image to images/common/ ?
Julien
Ulf
Ulf-D. Ehlert
2009-01-13 14:07:25 UTC (almost 17 years ago)
images
julien (Dienstag, 13. Januar 2009, 07:19):
Yes, obviously just a local problem. My working copy was fucked up and I had to checkout the changed directories again.
'make' will (hopefully) create
xml/
xml/fr/
xml/fr/images/
(There is a minor bug: empty directories xml/fr/images/{C,common} will be created too - I'll fix that.)
But we have also
'make' searches for image files in images/common/ and in images/C/, and checks if there is a corresponding localized image in images/fr/ - if so, it will create a symlink to the localized file, otherwise it creates a symlink to the image file in images/C.
The images in "images/common/" were just the images/*.* files which didn't belong to any special section (menus, filters, etc.).
Example:
1) For "images/C/dialogs/selection-border.png" there is a localized version "images/fr/menus/selection-border.png", then a symlink
xml/fr/images/menus/selection-border.png -> /path/to/images/fr/menus/selection-border.png
will be created. Of course, if there is a localized file with a different name, this won't work.
2) For "images/C/dialogs/examples/border-selection-02.png" there is no corresponding localized image, so 'make' creates the symlink
xml/fr/images/dialogs/examples/border-selection-02.png -> /path/to/images/C/dialogs/examples/border-selection-02.png
Then "html/fr/images" will be created as a symlink to "xml/fr/images", and you should have your French images back.
For 'en' I have changed the code so that there is the same directory structure as for the other languages, and making xml-en will create symlinks to the source files and to the image files.
You'll have to remove the symlink "xml/en", because now a directory "xml/en" will be created. (Maybe it's the right time for testing
"make [-n] [-f Makefile.GNU] clean".)
Good luck! Ulf
julien
2009-01-13 15:03:49 UTC (almost 17 years ago)
images
Thank you for the explanations.
That's a problem.
Can you give a line command that checks for non corresponding en-LANG image names?
Julien
Ulf-D. Ehlert
2009-01-13 19:11:04 UTC (almost 17 years ago)
images
julien (Dienstag, 13. Januar 2009, 15:03):
That's a problem.
find images/fr/ -name .svn -prune -o -type f -print | while read localized; do
english=images/C/${localized#images/*/} test -e $english || echo $localized done
I will reanimate our validate_references script that checks for broken image reference and orphaned image files, this should find images with different names.
Ulf
Ulf-D. Ehlert
2009-01-14 19:47:44 UTC (almost 17 years ago)
images
Ulf-D. Ehlert (Dienstag, 13. Januar 2009, 19:11):
Done. Try
make [-f Makefile.GNU] check-images-fr unless you are really happy - the output is rather depressing. :-(
(Don't forget to run autogen.sh.)
Ulf
julien
2009-01-15 09:43:10 UTC (almost 17 years ago)
images
Try
Three pages...
But check-images-fr lists as broken /common/ images that exist, for instance:
BROKEN: images/common/dialogs-icon-delete.png IN src/dialogs/channel-dialog.xml
and lists /C/ orphaned images. Only fr orphaned images should be listed IMO.
julien
Ulf-D. Ehlert
2009-01-15 18:28:45 UTC (almost 17 years ago)
images
julien (Donnerstag, 15. Januar 2009, 09:43):
No, 'make' will copy the image files in "common/" to your images directory "xml/fr/images", so the fileref attribute should read
It's just like we used to handle icons like next.png or tip.png. In fact, the images I moved to 'common/' were just these icons and some background images used by stylesheets, e.g. splash image and draft background (try "grep images/ stylsheets/*").
So for a fileref you always have to remove the second directory level (images/{C,common,fr}/path/to/image.png --> images/path/to/image.png).
If a file like "dialogs-icon-delete.png" is referred to only in the dialogs source files, IMHO it's better to leave it in the C/dialogs directory.
But we should consider renaming it to "delete-icon.png" or "delete.png", or even creating an icons subdir "images/C/dialogs/icons".
BTW, is it true that the callout icons are no longer used? Shouldn't we move them to docs/ or to src/images?
No, that was intended. There may be orphaned images in 'images/C' and localized versions (also orphaned. of course) in 'images/fr', so you are invited to fix (rename, remove, or what ever) both.
The validating script checks src/ and images/C + images/fr, but you can call it with different options and check whether or not the output is more useful:
tools/validate_references.py --verbose --broken --orphaned \ --imgdir=xml/fr/images [ --xmldir=xml/fr ]
Bye, Ulf
