msgmerge compendium feature
msgmerge compendium feature Ulf-D. Ehlert 08 Jan 21:59
  msgmerge compendium feature Daniel Nylander 09 Jan 00:35
   msgmerge compendium feature Ulf-D. Ehlert 09 Jan 18:39
Ulf-D. Ehlert
2009-01-08 21:59:43 UTC (almost 17 years ago)
I have changed the Makefile.GNU to use the compendium feature of the msgmerge program.
When updating a po file, e.g. with
make -f Makefile.GNU --assume-new=pot/foo/bar/baz.pot \ po/xx/foo/bar/baz.po
the new code will look for files named "Compendium.po" (capital "C") in po/xx/foo/bar, po/xx/foo, and /po/xx. These compendium files should contain common translations to be used as defaults.
For now the compendium files have to be maintained manually (without a common pot file). Have a look at my sample files po/de/menus/Compendium.po and po/de/menus/colors/Compendium.po.
If you have any problems, you can disable this feature with
make -f Makefile.GNU ... COMPENDIUM=""
If there are no problems, I'll change Makefile.am too.
Bye, Ulf
Daniel Nylander
2009-01-09 00:35:29 UTC (almost 17 years ago)
tor 2009-01-08 klockan 21:59 +0100 skrev Ulf-D. Ehlert:
This is great!
I actually created a Compendium from all the Swedish files using the pocompendium script from Translate Toolkit, i.e.
cd po/sv pocompendium Compendium.po -d .
That will give me a Compendium.po with all unique strings (~ 10,000). This also shows that I have translated roughly 10% of all strings.
The problem I still got is that make will delete some of my PO files and replace them with new empty ones
Regards, Daniel
Ulf-D. Ehlert
2009-01-09 18:39:53 UTC (almost 17 years ago)
Daniel Nylander (Freitag, 9. Januar 2009, 00:35):
I noticed this too, but wasn't able to reproduce it.
Still don't know when or why it happens...
Ulf
