Gimp-docs Digest, Vol 56, Issue 18
8 of 12 messages available
mailman.5.1231358409.26836.... 07 Oct 20:29
  Gimp-docs Digest, Vol 56, Issue 9 Vitaly Lomov 08 Jan 17:55
   Gimp-docs Digest, Vol 56, Issue 9 julien 08 Jan 20:30
    Gimp-docs Digest, Vol 56, Issue 9 Ulf-D. Ehlert 08 Jan 22:00
mailman.236217.1231523086.1... 07 Oct 20:29
  Gimp-docs Digest, Vol 56, Issue 11 Vitaly Lomov 10 Jan 13:45
mailman.3.1232395204.7908.g... 07 Oct 20:29
  Gimp-docs Digest, Vol 56, Issue 19 Vitaly Lomov 21 Jan 10:58
mailman.5.1232308804.969.gi... 07 Oct 20:29
  Gimp-docs Digest, Vol 56, Issue 18 Vitaly Lomov 21 Jan 11:13
   Gimp-docs Digest, Vol 56, Issue 18 Ulf-D. Ehlert 21 Jan 20:22
   Gimp-docs Digest, Vol 56, Issue 18 Ulf-D. Ehlert 23 Jan 14:01
Vitaly Lomov
2009-01-08 17:55:18 UTC (over 16 years ago)
Date: Wed, 07 Jan 2009 20:33:48 +0100 From: julien
Subject: Re: [Gimp-docs] Cygwin and po, second steps
julien, how did you install docbook 4.5? Maybe I can replicate the setup on cygwin. If there are not too many files to copy, I can do it manually.
I am working under OpenSuse-11.0 : dockbook-4.5 IS installed...
Julien, I meant, can you describe the layout of your 4.5 install so that I can replicate it on my machine until Cygwin teams provides the package? I don't know if I can install opensuse package for docbook on cygwin, but I would like to have a working system.
julien
2009-01-08 20:30:11 UTC (over 16 years ago)
Hi Vitaly,
Sorry, I can't tell you that. Under opensuse, we have an automatic system to update programs, and for new programs, we have a One-Click install system. So, I don't know how and when docbook-4.5 was installed. But this would no longer be a problem if everybody agree removing the sections in xml files. I'll do that for every file I'll will update.
Julien
Ulf-D. Ehlert
2009-01-08 22:00:19 UTC (over 16 years ago)
julien (Donnerstag, 8. Januar 2009, 20:30):
Vitaly, if you understand spec files I can send you my DocBook-4.5 spec file I used to install 4.5 on SuSE Linux 9.3.
[x] agree
[ ] don't agree
Ulf
Vitaly Lomov
2009-01-10 13:45:15 UTC (over 16 years ago)
Date: Thu, 8 Jan 2009 22:00:19 +0100 From: "Ulf-D. Ehlert"
Subject: Re: [Gimp-docs] Gimp-docs Digest, Vol 56, Issue 9 To: gimp-docs@lists.xcf.berkeley.edu Message-ID:
Content-Type: text/plain; charset="iso-8859-1"
If you are talking about dtd file, I have. If something else, then sure, I'll have a look
Vitaly Lomov
2009-01-21 10:58:09 UTC (over 16 years ago)
... but I can't explain this particular difference. I tried touch src/using/docks.xml &&
make -f Makefile.GNU po/de/using/docks.po and get
grep -B1 'See also' po/de/using/docks.po msgid ""
"See also Dialogs and Docking"
so here's no such difference.
Which gettext version do you use? Maybe different gettext versions produce different output? (I have gettext-0.17 installed.)
I use 0.17-3
If I commit this, people will think I am a prolific writer :) and the ChangeLog will not reflect the work I actually did. Any suggestions? I am aware that I can update individual po files with some Makefile magic, but how can I build the html and avoid the problem described?
Hmm, I do not work directly on the SVN working copy, instead I have another copy on "/tmp" and commit only files I have edited. But we can't expect everybody to work this way, so it seems that we really have a problem here...
Now that I know, I can work in temp. That mean, thogh, I need to have a complete copy of gimp so that html can be built. That's a pain to maintain.
Vitaly Lomov
2009-01-21 11:13:26 UTC (over 16 years ago)
I have added some new targets to Makefile.GNU:
awesome
I also changed making of HTML previews (drafts), now make [-f Makefile.GNU] preview-xml/xx/path/to/xmlfile.xml will produce a single HTML file (remember that links can't work in those draft HTML files),
I tried that (for ru/concepts/concepts.xml), it worked, and got the page with white text on white background. Is it because css is not linked?
Ulf-D. Ehlert
2009-01-21 20:22:10 UTC (over 16 years ago)
Vitaly Lomov (Mittwoch, 21. Januar 2009, 11:13):
What's wrong with white text on white background?? You will never have to worry about typos... ;-)
Ok, if you really want to know what's going on:
First check stylesheets/*.css and html/ru/*.css.
The preview commands should unconditionally copy the CSS files. Try
make ... VERBOSE=2
then you should see
cp -f ./stylesheets/*.css ./stylesheets/${lang}/*.css\ ${destdir} 2>/dev/null; \
You can change the above copy command to "cp -f -v ..." and remove the " 2>/dev/null" (but not the semicolon) from the command to produce more output.
Bye,
Ulf
Ulf-D. Ehlert
2009-01-23 14:01:39 UTC (about 16 years ago)
Forget my last email, I've got it (when I remembered that the dark backround for previews is an image, not a color): obviously I removed the code to create the html images directory when I changed the preview stuff.
Workaround: "make [-f Makefile.GNU] html/ru/images" should create the images directory if necessary and a link html/ru/images -> ../../xml/ru/images.
I will add the missing code to the Makefiles and a fallback to the stylesheet.
Bye,
Ulf
