Cygwin and .po, first steps
Cygwin and .po, first steps Vitaly Lomov 05 Jan 12:33
  Cygwin and .po, first steps julien 05 Jan 14:51
  Cygwin and .po, first steps Ulf-D. Ehlert 05 Jan 21:56
Vitaly Lomov
2009-01-05 12:33:58 UTC (almost 17 years ago)
While I still get errors (below), I got the index.html file in html/ru with images.
The command was "make -f Makefile.GNU", no fancy target specification.
I use cygwin (latest 2.573.2.3) on Win2K. Packages I had to get for the new build system: gettext(0.17-3, 178k) - that fixes msggmt(1) error - thanks to Ulf. gettext-devel - probably not needed, but just in case, it had gettext in the name.
pngcrush(1.6.7-1, 43k) - that fixes the warning about png image optimization libxml2 - I thought that would fix the libxml2 module not found error, but it didn't, you need
python-libxml2(2.7.2-1, 204k) - python bindings
the errors(warnings): 1.Warning: cannot load module 'docbook', using automatic detection (-a). -Happens for every POT file, just clutters the screen, the error is in tools/xml2po file
2.*** Making html for ru ...
mkdir: cannot create directory `html/ru': Permission denied -I don't know why the permission would be denied, I am a user with admin rights. I created the html/ru folder manually, no complaints afterwards.
3.make: *** [html/ru/index.html] Error 1 I/O error : Attempt to load network entity http://www.docbook.org/xml/4.5/docboo kx.dtd
xml/ru/menus/file-close.xml:2: warning: failed to load external entity "http://w ww.docbook.org/xml/4.5/docbookx.dtd" //OASIS//DTD DocBook XML V4.5//EN" "http://www.docbook.org/xml/4.5/docbookx.dtd" -That's a bigger deal. Cygwin doesn't provide docbook 4.5 package yet, 4.4 is the latest. I don't know what this error effects, since I got my local xml and html files.
4. No template matches placeholder-1 in phrase. -Got a few of those, not idea what to do. May be I will get placeholder in the final html?
cool: nice to see the todo [PO] po/ru/menus/xtns-introduction.po 3 translated messages, 4 fuzzy translations, 2 untranslated messages. [XML] xml/ru/menus/xtns-introduction.xml
julien
2009-01-05 14:51:01 UTC (almost 17 years ago)
Oh sorry,
I changed "4.3" for "4.5" in this file as a test and I forgot it :-( But that's an interesting error : no hope to get rid of the tag because this lack in Cygwin.
Julien
Ulf-D. Ehlert
2009-01-05 21:56:39 UTC (almost 17 years ago)
Hi Vitaly,
Vitaly Lomov (Montag, 5. Januar 2009, 12:33):
According to http://cygwin.com/packages/gettext/gettext-0.17-3 it seems that you don't need gettext, but gettext-devel is required.
pngcrush(1.6.7-1, 43k) - that fixes the warning about png image optimization libxml2 - I thought that would fix the libxml2 module not found error, but it didn't, you need python-libxml2(2.7.2-1, 204k) - python bindings
Yes, we still have a problem with xml2po. I will write a separate email describing the problem, we will have to decide what to do.
I think making html/images failed, I will fix that.
This is not a good idea...
3.make: *** [html/ru/index.html] Error 1 I/O error : Attempt to load network entity http://www.docbook.org/xml/4.5/docboo kx.dtd xml/ru/menus/file-close.xml:2: warning: failed to load external entity "http://w ww.docbook.org/xml/4.5/docbookx.dtd" //OASIS//DTD DocBook XML V4.5//EN"
Grrr, DocBook 4.5 is released october 2006!
The xml2po problem mentioned above.
Ulf
