ANNOUNCE: GIMP 2.6.4
Happy New Year!
The GIMP developers welcome you in the new year with the fourth bug-fix
release in the stable GIMP 2.6 series. The source can be downloaded from
ftp.gimp.org. Binary packages for the various supported platforms should
become available soon; please check at http://gimp.org/downloads/
Overview of Changes from GIMP 2.6.3 to GIMP 2.6.4
* Bugs fixed:
565223 – Perspective transformation jagged edges / comb effect
563985 – jpg save dialog: "cancel" is treated like "commit"
for settings
564087 – Using clone tool on a layer with a part out of canvas
causes crashes
564593 – crash when the drawable is changed while a color tool
is active
564869 – GIMP crashes on selecting Tools->GEGL operation
565138 – python-fu-foggify does not check if image is in rgb mode
563130 – Hue selection mode does not cross the 0-360 degrees line
563179 – Scrollbars not resized when we extend the canvas size
562459 – PF_PALETTE: 'TypeError' when used in a plugin that is
registered in
562427 – Compilation with --as-needed
562386 – PF_SLIDER and PF_SPINNER 'Step' values do not change
consistently...
562366 – Default image dimensions are not correctly
transferred in the file/new dialog box
561899 – GIMP can't save to mounted filesystem if file exists
* Updated translations:
Greek (el)
Hindi (hi)
Hungarian (hu)
Italian (it)
Japanese (ja)
Korean (ko)
Slovenian (sl)
Swedish (sv)
Tamil (ta)
Simplified Chinese (zh_CN)
Users and distributors are also encouraged to update GEGL to version
0.0.22, which has been released yesterday. The new GEGL release not only
provides some nice speedups, it also features a new vector path
representation infrastructure. This will eventually become used in GIMP
to provide support for editable vector objects.
