Problem setting up for dev
Problem setting up for dev Henrik Akesson 30 Dec 15:05
  Problem setting up for dev Martin Nordholts 30 Dec 16:46
   Problem setting up for dev David Evans 30 Dec 18:05
Henrik Akesson
2008-12-30 15:05:46 UTC (over 16 years ago)
hope this is not a stupid question... I've done quite a lot of research about it but didn't find an answer.
I've setup and compiled, noting that at the end of the compile there's a problem with the modules (not sure what is done here):
---------------------------------- Making all in data
make[4]: Nothing to be done for `all'. --[Updating sample compositions]--
./OpenRaster-00.xml
** Message: Module
'../../operations/affine/.libs/affine.so.dSYM/Contents/Resources/DWARF/affine.so' load error: dlopen(../../operations/affine/.libs/affine.s o.dSYM/Contents/Resources/DWARF/affine.so, 10): no suitable image found. Did find:
../../operations/affine/.libs/affine.so.dSYM/Contents/Resources/DWARF/affine.so: can't map
There are the same message for (I belive) every module.
Full output of autogen: http://sites.google.com/site/computerresearcher/gegl/gegl-developer/autogen Full output of make:
http://sites.google.com/site/computerresearcher/gegl/gegl-developer/make
And when running (using GEGL_PATH=/Users/hakesson/Projects/settingup/gegl/operations/) I get: ----------------------------------
** Message: Module
'/Users/hakesson/Projects/settingup/gegl/operations/generated/.libs/svg-multiply.so.dSYM/Contents/Resources/DWARF/svg-multiply.so' load err
or: dlopen(/Users/hakesson/Projects/settingup/gegl/operations/generated/.libs/svg-multiply.so.dSYM/Contents/Resources/DWARF/svg-multiply.so, 10): no suitable
/Users/hakesson/Projects/settingup/gegl/operations/generated/.libs/svg-multiply.so.dSYM/Contents/Resources/DWARF/svg-multiply.so: can't map
Same message for every module...
Full output: http://sites.google.com/site/computerresearcher/gegl/gegl-developer/run
Would you have an idea of why this is happening?
I've had strange compilation problems in the beginning because of missing dependencies (which are now installed using macports), but on this one I'm a bit lost.
Thanks,
Henrik
Martin Nordholts
2008-12-30 16:46:06 UTC (over 16 years ago)
Hi
As far as I know there is no one making regular testing on Mac OS X so feel free to be the one. Your problems look very Mac OS X specific so I'm not able to help further, sorry.
BR, Martin
David Evans
2008-12-30 18:05:22 UTC (over 16 years ago)
Hi
BR, Martin
