Feature proposal: Edit paths in external program
14 of 15 messages available
Feature proposal: Edit paths in external program Iljoa 28 Dec 08:58
  Feature proposal: Edit paths in external program Martin Nordholts 28 Dec 17:53
   Feature proposal: Edit paths in external program Alexandre Prokoudine 28 Dec 21:02
  Feature proposal: Edit paths in external program Sven Neumann 28 Dec 22:58
Feature proposal: Edit paths in external program Mirai Warren 30 Dec 19:51
  Feature proposal: Edit paths in external program Alexandre Prokoudine 30 Dec 21:50
7210566f0812290100v2dfcea68... 07 Oct 20:27
  Feature proposal: Edit paths in external program Sven Neumann 29 Dec 12:19
   Feature proposal: Edit paths in external program gg 29 Dec 12:40
    Feature proposal: Edit paths in external program Sven Neumann 29 Dec 12:51
   Feature proposal: Edit paths in external program Alexandre Prokoudine 29 Dec 15:28
    Feature proposal: Edit paths in external program Sven Neumann 29 Dec 16:41
   Feature proposal: Edit paths in external program Iljoa 29 Dec 19:43
    Feature proposal: Edit paths in external program Martin Nordholts 29 Dec 22:07
     Feature proposal: Edit paths in external program Henk Boom 30 Dec 01:29
Iljoa
2008-12-28 08:58:48 UTC (over 16 years ago)
I want to propose a feature request; I did this already in Bug 565776; there I was told this should be discussed here, and here I am: There should be the option to edit path layers in an external program. It could work this way:
Right click on a path, choose "edit with external program", open it with the default editor for svg-files. In my case this would be Inkscape. In Inkscape there should not only be the path, but also all the other layers as a bitmap in the background, so I can see, how the path interacts with the rest of the image. If I
save in Inkscape, the path is refreshed in GIMP automatically, the bitmap background is dropped.
It could of course also work in another way. Greetings
Das Auge
Martin Nordholts
2008-12-28 17:53:30 UTC (over 16 years ago)
Hi
It would be nice to have but getting this feature to work good requires quite a bit of work both on GIMP and Inkscape.
- Martin
2008-12-28 21:02:41 UTC (over 16 years ago)
Besides native path editing in gegl's test tool is getting really interesting, and once it's inside GIMP, one would probably not wish going to edit paths elsewhere :)
Alexandre
2008-12-28 22:58:08 UTC (over 16 years ago)
You are aware that you can drag a path from the GIMP Paths dialog into Inkscape and edit it there? Unfortunately I can't tell you how you can easily get that path back into GIMP. But if I remember correctly, you should be able to drop an SVG path on GIMP. So if Inkscape provided a way to drag out the path, you'd be all set.
2008-12-29 12:19:42 UTC (over 16 years ago)
How much work exactly?
The point is that given the amount of active developers on GIMP we have enough feature proposals to work on for the next two decades. And each of those features appears more important than adding yet another way to exchange paths between GIMP and Inkscape. So the best thing we can do at this point is to ask the Inkscape developers to add a way to get a path back into GIMP easily.
But I see also a problem: The paths in GIMP seem to support only a trackle of the svg format.
What do you mean, a trackle of the SVG format? Can you be more specific about this, please?
gg
2008-12-29 12:40:58 UTC (over 16 years ago)
SVG is not just a ... but a full blown xml spec that includes javascript and DOM. How much of that is handled by GIMP?
I'm also unaware of the word trackle but I think the meaning is clear.
/gg
2008-12-29 12:51:23 UTC (over 16 years ago)
Sorry, but the sentence in question was "The paths in GIMP seem to support only a trackle of the svg format.". So we are not discussing full support of SVG here, but only paths in SVG files. And as far as I can see GIMP supports all features of SVG paths. SVG paths don't cover all aspects of GIMP paths though, but they can be used as a reasonable approximation.
2008-12-29 15:28:33 UTC (over 16 years ago)
It already works with Inkscape from SVN trunk. You just copy a path in Inkscape to clipboard and Ctrl+V it in GIMP's image window.
Alexandre
2008-12-29 16:41:15 UTC (over 16 years ago)
Seems somewhat hard to discover that you can get a path from GIMP into Inkscape using DnD and need to use the clipboard to get it back. Ideally it should be possible to exchange paths in both directions using either DnD or the clipboard.
Iljoa
2008-12-29 19:43:08 UTC (over 16 years ago)
I meant a trickle (sorry for the typo) and to be more specific: In GIMP I cannot define a fill color, stroke color, type and width. I hava a naked bezier curve without any additional information.
All I can do is to modify the path and to draw it as a bitmap graphic.
Great, I am looking forward to the next Inkscape release.
Martin Nordholts
2008-12-29 22:07:27 UTC (over 16 years ago)
It is worth mentioning that GIMP 2.8 is planned to have basic vector layers which supports exactly that. The enhancement request to track is:
Bug 557970 – Merge vector layers GSoC Project http://bugzilla.gnome.org/show_bug.cgi?id=557970
- Martin
Henk Boom
2008-12-30 01:29:24 UTC (over 16 years ago)
2008/12/29 Martin Nordholts :
Wow, I had no idea there was progress on this front! It makes me very happy that my code won't go to waste. =)
Henk
Mirai Warren
2008-12-30 19:51:55 UTC (over 16 years ago)
Isn't the GIMP supposed to editing photos and creating original works with pixel-based formats? It still lacks functionality or ease of use with those tasks, so why should paths and SVG need support past what it has now? If you need to work with paths and non-SVG graphics at the same time, then tighter integration with Inkscape or some other vector creation programme is what you should push for.
2008-12-30 21:50:16 UTC (over 16 years ago)
Artificial limitation for creative process tends to bite back badly
Alexandre
