First experience with po's
First experience with po's julien 27 Dec 18:34
  First experience with po's Ulf-D. Ehlert 28 Dec 13:33
   First experience with po's julien 28 Dec 18:11
julien
2008-12-27 18:34:02 UTC (almost 17 years ago)
Hi all,
Here is my first experience using po's (po/fr/../doc.po, pot/../doc.pot, src/../doc.xml). I consider two cases:
A - Translating only: No change in the help structure; no add, no deletion. Only translation of the strings.
1- Using the po file is the simplest way. a/ First update this po to get strings that have changed by using the following command:
msgmerge -U po/fr/../doc.po
This will add changed strings that are marked with a "Fuzzy" comment. Edit this updated po files, searching for "Fuzzy". b/ When your file is OK, validate it with this command (being in the folder containing doc.po):
msgfmt -c --stat doc.po
This displays possible errors and some stats and generate a doc.mo file that is of no use here.
c/ make the "svn diff"
2- You may want to work on a xml file rather than on a po: a/ update the po files you want to use as above b/ Create the xml files for your language (being in "trunk"): make -f Makefile.GNU xml-fr for example. This creates a xml folder in "trunk". c/ Edit the wanted xml file.
d/ We can't validate xml for the moment. But you can open the file in a web browser (Firefox) that will detect some errors. Or copy the file in an old sandbox (before xml2po migration) and run make validate...:-(
e/ Transform your xml file to po (being in trunk): xml2po -e -o -r src/../doc.xml
(the english doc.xml).
f/ cut-paste the doc.po file into the po directory. g/ Goto 1b
B - Updating gimp-help-2
1- Edit the src/../doc.xml file (english). Or edit a xml file in your language and translate it after.
2- Validate it
3- Transform the updated doc.xml file to doc.pot: xml2po -e -o doc.pot doc.xml
4- Edit the doc.xml file in your language, validate it 5- goto 1e
You may want to view your xml file in html. Waiting for Ulf's make html-fr, I use
$yelp file:///home//.../trunk/xml//doc.xml Unfortunately, images are not displayed by yelp. How to do?
I would be very pleased if you can provide a more simple way to work.
Julien
Ulf-D. Ehlert
2008-12-28 13:33:59 UTC (almost 17 years ago)
Hi Julien,
julien (Samstag, 27. Dezember 2008, 18:34):
Use "make po-fr" or "make po/fr/../doc.po".
Should we really add a make target for checking single po files? Workaround: "make xml-fr" - it this succeeds, the po file should be ok.
msgfmt will find only simple errors like missing quote (") characters etc., but it won't find DocBook errors, which are IMHO more likely.
No! Edit the English xml file src/.../doc.xml. "make validate" should work now, checking the English xml files. Then try "make po-fr" and edit po/fr/.../doc.po. Try "make xml-fr" to create (and thus validate) the French xml file(s). Or "make xml/fr/.../doc.xml" to create just a single xml file. "make xml/fr/.../doc.draft" (extension '.draft' insted of '.xml') should also work and should produce an HTML preview file.
"make xml/fr/.../doc.draft" should work, "make validate" too.
No.
src/../doc.xml (the english doc.xml).
"make po-fr" or "make po/fr/../doc.po", "make xml-fr".
"Goto" considered harmful... ;-)
Yes.
No!
2- Validate it
"make pot" will create pot/../doc.pot.
No!
5- goto 1e
Just try "make html-fr" and report what's going wrong.
, I use
I guess we can't use yelp. As far as I understand it, yelp will try to create the HTML manual on-the-fly, so this tool is only useful for small manuals.
For yelp we would have to create a new "mini" manual.
Translating only:
1. "make po-fr" to be up-to-date
2. edit po/fr/.../doc.po
3. "make xml-fr" or "make xml/fr/.../doc.xml" to check the result 4. "make xml/fr/.../doc.draft" to see an HTML preview 5. "make status-fr" to see which po files have to be edited [not yet implemented, but I will add this feature today]
Adding/changing English documents: 1. edit src/.../doc.xml
2. "make validate"
Adding/changing French documents: 1. Don't! Just update the respective po files.
Of course there are still bugs and some of the command may fail...
Bye, Ulf
julien
2008-12-28 18:11:29 UTC (almost 17 years ago)
Oh sorry,
I answered to your first message reading the second one. I will have a try with all that. If I well understand, I can work on several files and "make" will treat all of them at the same time.
My question about autogen and configure remains valid.
No.
Yes.
No!
2- Validate it
No!
5- goto 1e
, I use
Translating only:
2. "make validate"
Bye, Ulf
