autogen.sh [Was: Updating POT's]
7 of 7 messages available
Updating POT's julien 27 Dec 08:34
Updating POT's Ulf-D. Ehlert 28 Dec 12:09
  Updating POT's julien 28 Dec 17:57
   Updating POT's Ulf-D. Ehlert 28 Dec 21:07
    Updating POT's Marco Ciampa 29 Dec 03:05
     Updating POT's Ulf-D. Ehlert 29 Dec 18:09
    autogen.sh [Was: Updating POT's] Ulf-D. Ehlert 31 Dec 12:27
julien
2008-12-27 08:34:54 UTC (almost 17 years ago)
Updating POT's
Hi Ulf,
I saw that you can update the english part of every languages po at the same time. How do you do that?
It seems that no "fuzzy" comment is created. I can do this for one language with msgmerge, getting "fuzzy" comments.
Probably I cant use your method to update to v2.6 and translators will have to use msmerge on every po file before translating.
All the best,
Julien
Ulf-D. Ehlert
2008-12-28 12:09:03 UTC (almost 17 years ago)
Updating POT's
Hi Julien,
julien (Samstag, 27. Dezember 2008, 08:34):
I edited the orginal multi-lang files causing problems and applied the migrate script to those files.
xml2po produces no "fuzzy" comments when initializing po files.
Why did you use "msgmerge"? Everything should be done with "make".
If you have an old patch which has to be applied to the old multi-lang files, you can mail it to me and I try to integrate it.
Otherwise you just have to commit the changed src files and the updated French po files. The remaining po files should be updated by the respective translators.
Bye,
Ulf
julien
2008-12-28 17:57:52 UTC (almost 17 years ago)
Updating POT's
Because I didn't know that Makefile was done for that. I opened the Makefile (Why Make and Makefile.GNU?) but I don't understand it.
Do I must do a ./autogen.sh or a ./configure before using it? Please give an example: the menus/edit-cut.xml is updated. I want to create (update?) the POT file and the po/fr/edit-cut.po file. How can I do that with "make"?
Cheers,
Julien
Ulf-D. Ehlert
2008-12-28 21:07:51 UTC (almost 17 years ago)
Updating POT's
julien (Sonntag, 28. Dezember 2008, 17:57): [...]
The default build system uses autoconf and automake. You have to run "autogen.sh" once and then later configure (this is also done automatically by autogen.sh), e.g. to set ALL_LINGUAS.
The (default) Makefile is generated by "configure". This is the same as before, except that the Makefile targets and/or commands had to be changed, of course.
"Makefile.GNU" is meant to be used without any autogen or configure scripts (maybe a very simple configure script later). I still think we don't need the autotools (autoconf, automake, configure.ac, Makefile.am, autogen.sh) and just started to try it...
For now, both Makfile and Makefile.GNU should behave the same. Ok, sometimes I use Makefile.GNU for testing - e.g. try make -f Makefile.GNU status-fr
Yes, run ./autogen.sh [--without-gimp] [LINGUAS="en fr"] to initialize the default build system.
Note that you have to re-run autogen.sh if you install new software like "dblatex" or "docbook2odf" -- using Makefile.GNU this shouldn't be necessary.
make po/fr/edit-cut.po (or make po-fr).
Bye, Ulf
Marco Ciampa
2008-12-29 03:05:28 UTC (almost 17 years ago)
Updating POT's
I think you meant:
./autogen.sh [--without-gimp] [ALL_LINGUAS="en fr"]
or
export ALL_LINGUAS="en fr"
./autogen.sh --prefix=/usr --without-gimp
bye
Ulf-D. Ehlert
2008-12-29 18:09:09 UTC (almost 17 years ago)
Updating POT's
Marco Ciampa (Montag, 29. Dezember 2008, 03:05):
I think you meant:
or
Oops, you are right.
BTW, I think "ALL_LINGUAS" is a bad name, pretending there's a "LINGUAS" variable too containing a subset of "ALL_LINGUAS".
Bye, Ulf
Ulf-D. Ehlert
2008-12-31 12:27:14 UTC (almost 17 years ago)
Ulf-D. Ehlert (Sonntag, 28. Dezember 2008, 21:07):
I have to correct myself: Since (while) we are using a trick in Makefile.am and autogen.sh, you'll have to run "autogen.sh" whenever Makefile.am has been changed. This is not the default autotools behaviour, though.
Ulf
