Strange Error
Strange Error Pablo Yaggi 17 Dec 15:31
  Strange Error Kevin Cozens 17 Dec 21:54
Pablo Yaggi
2008-12-17 15:31:05 UTC (almost 17 years ago)
Strange Error
Working with gimp 2.6 this segment of codes
(if (= (car (gimp-drawable-is-rgb image)) FALSE) (gimp-image-convert-rgb image) )
gives me this error
Error while executing script-fu-mirror-table:
Error: Procedure execution of gimp-image-convert-rgb failed on invalid input arguments: Image 'file:///home/pablo/glam.jpg' (1) is already of type 'rgb'
Bests,
Pablo
(Martin told me my font was too small, is it right now ? )
Kevin Cozens
2008-12-17 21:54:45 UTC (almost 17 years ago)
Strange Error
The above code is checking the type of a drawable and using this information to decide whether you need to convert an image.
If you want to convert the whole image to RGB only if it is not already in RGB format, you need to test the value returned by gimp-image-base-type.
