the symbol for inch can be ' ?
the symbol for inch can be ' ? Cristian Secar? 18 Nov 10:01
  the symbol for inch can be ' ? Andrew A. Gill 18 Nov 10:35
  the symbol for inch can be ' ? Daniel Hornung 18 Nov 15:31
   the symbol for inch can be ' ? Paka 18 Nov 16:21
  the symbol for inch can be ' ? Sven Neumann 18 Nov 23:11
Cristian Secar?
2008-11-18 10:01:36 UTC (over 16 years ago)
Somewhere in the po-plug-ins file there is this string:
The unit's symbol if it has one (e.g. \"'\" for inches). The unit's abbreviation is used if doesn't have a symbol.
Is this correct ? As far as I know the symbol for inch is ", not '.
Cristi
Andrew A. Gill
2008-11-18 10:35:11 UTC (over 16 years ago)
I believe the definitive discussion of this is in This is Spinal Tap, where they mistakenly request a model of Stonehenge 18" high, instead of 18', resulting in a prop that was in danger of being crushed by a dwarf.
Daniel Hornung
2008-11-18 15:31:10 UTC (over 16 years ago)
Cristi
Paka
2008-11-18 16:21:19 UTC (over 16 years ago)
* Daniel Hornung [11-18-08 09:59]:
Indeed, wikipedia says it's the double prime symbol:
http://en.wikipedia.org/wiki/Inch http://en.wikipedia.org/wiki/Prime_(symbol) http://www.isthisthingon.org/unicode/index.php?page=02&subpage=0&glyph=02033
which is different from quotation marks. I don't know if that plays a role here though :)
Although I have seen the "double prime" used to denote "inch" measurement, that usage has been so rare as to approach non-existence. The double "quotation" mark more recognizable, less mis-understood and almost universally used, to the point that "double prime" could be mis-understood and appear to be in error.
It is my humble opinion that the double quotation mark should be utilized.
2008-11-18 23:11:11 UTC (over 16 years ago)
Thanks for spotting this mistake. Fixed in trunk.
