stuck with the metadata plugin
stuck with the metadata plugin Roman Joost 06 Nov 17:10
Roman Joost
2008-11-06 17:10:59 UTC (over 16 years ago)
Hi list,
I initially sent this mail to Raphaël, who seems to be away of some kind. I think there are a lot of extraordinary C programmers on the list so I give it a try:
I'm still working on the metadata browser. Though haven't gone very far, also because I can't spend much time in this. The manual drains more time than I thought.
Anyways - I hope you can help me in a (hopefully) simple question. If you don't have time currently and think the question is better be answered on the developer mailing list, let me know.
I'm currently just trying to store the EXIF metadata in the XMP block during load of a JPEG file.
The weird thing just happens during the few steps:
1. loading the JPEG 2. call:
jpeg-load.c: L 330
gimp_metadata_store_exif (image_ID, exif_data);
3. call: gimpexif.c: L 70
return_vals = gimp_run_procedure ("plug-in-metadata-decode-exif", &nreturn_vals, GIMP_PDB_IMAGE, image_ID, GIMP_PDB_INT32, exif_data->size, GIMP_PDB_INT8ARRAY, exif_data, GIMP_PDB_END); 4. call:
metadata.c: L 454
data = (ExifData *) param[2].data.d_int8array; exif_data_size = param[1].data.d_int32;
if (! xmp_merge_from_exifbuffer (xmp_model, data, exif_data_size, &error))
5. call: exif-decode.c: L 5
if (data->size) exif_iter_content (xmp_model, data);
6. call: exif-decode.c: L 104
for (i=0; i < EXIF_IFD_COUNT; i++) {
content = data->ifd[i]; /* BANG! */
At this point, I'm iterating over the exif content and entries. When I try to access the entries I'm getting a Segmentation fault *Bang*.
A segmentation fault also happens if I'm trying to access the EXIF entries at the point in the metadata.c file. So I'm just guessing that I missed something but I don't have any clue what ...
I created a patch against the current TRUNK with my changes and put it on:
http://amy.gocept.com/~roman/metadata.patch
It's not productive code, just my lousy attempt to get more the EXIF content displayed in the metadata browser ;) And of course more experience with C.
Thanks for any helpful ideas!!!!
