English screenshots on Spanish version of the GIMP help
2 of 3 messages available
English screenshots on Spanish version of the GIMP help David Padron Alvarez 03 Nov 15:50
  English screenshots on Spanish version of the GIMP help Roman Joost 05 Nov 13:33
mailman.5.1225656007.15410.... 07 Oct 20:29
2008-11-03 15:50:08 UTC (over 16 years ago)
¿How can I help the GIMP Team replacing the screnshots of the GIMP interface and menus that are in English on the Spanish version of the help files and PDF version?
Linux User #384686 #include< David Padrón Álvarez > int main(){ /* Universidad de las Ciencias Informáticas Facultad de Bioinformática e Información Biomédica */ using namespace Estudiante ; RealTimeEncoder encoder; NetProtocols protocol=encoder.detect(); }return 0;
-----Original Message----- From: gimp-docs-bounces@lists.XCF.Berkeley.EDU on behalf of gimp-docs-request@lists.XCF.Berkeley.EDU Sent: Sun 02/11/2008 15:00
To: gimp-docs@lists.XCF.Berkeley.EDU Subject: Gimp-docs Digest, Vol 54, Issue 2
Send Gimp-docs mailing list submissions to gimp-docs@lists.XCF.Berkeley.EDU
To subscribe or unsubscribe via the World Wide Web, visit https://lists.XCF.Berkeley.EDU/mailman/listinfo/gimp-docs or, via email, send a message with subject or body 'help' to gimp-docs-request@lists.XCF.Berkeley.EDU
You can reach the person managing the list at gimp-docs-owner@lists.XCF.Berkeley.EDU
When replying, please edit your Subject line so it is more specific than "Re: Contents of Gimp-docs digest..."
Today's Topics:
1. Re: PDF version of help documentation (Mark Beihoffer)
Message: 1 Date: Sat, 1 Nov 2008 14:35:33 -0500 From: "Mark Beihoffer"
Subject: Re: [Gimp-docs] PDF version of help documentation To: gimp-docs@lists.xcf.berkeley.edu Message-ID:
Content-Type: text/plain; charset="utf-8"
So, I'd still really like the help files installed correctly with the gimp on OpenBSD. A PDF version would be acceptable, but I'd prefer the help file to compile and install correctly under OpenBSD.
OpenBSD 4.4 shipped today, so perhaps now is the time to create a port or package for OpenBSD 4.5? It will be out in six months, which should be plenty of time.
I'd be happy to help in any way I can.
Thanks,
- Mark Beihoffer
Today's Topics:
1. Re: Installing GIMP help files (Sven Neumann) 2. PDF version of help documentation (Phillip M. Feldman) 3. Re: PDF version of help documentation (Roman Joost) 4. Re: PDF version of help documentation (Sven Neumann)
Message: 1 Date: Fri, 31 Oct 2008 21:06:39 +0100 From: Sven Neumann
Subject: Re: [Gimp-docs] Installing GIMP help files To: Roman Joost
Cc: GIMP Docs
Message-ID:
On Fri, 2008-10-31 at 14:57 +0100, Roman Joost wrote:
But on a second thought and a check at the Makefile I think we never released the manual as pre-built HTML files
I am very sure that the build system was initially designed to distribute pre-built HTML files. And I am also sure that this used to be done at some point in history. The installation instructions for the user manual still clearly state this.
Message: 2 Date: Sat, 01 Nov 2008 09:05:28 -0700 From: "Phillip M. Feldman"
Subject: [Gimp-docs] PDF version of help documentation To: gimp-docs@lists.XCF.Berkeley.EDU Message-ID:
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
The current help system requires that GIMP be installed first. It would be great if one could simply download a PDF file, with no dependence between the documentation and the GIMP software.
Phillip M. Feldman
Message: 3 Date: Sat, 1 Nov 2008 18:38:39 +0100 From: Roman Joost
Subject: Re: [Gimp-docs] PDF version of help documentation To: GIMP Docs
Message-ID:
Hi Phillip,
we provide PDF builts of the documentation. Though they're currently a bit outdated, but we will update them as soon as possible.
You can find them at:
http://docs.gimp.org/download.html
Greetings, --
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
-------------- next part -------------- A non-text attachment was scrubbed... Name: not available
Desc: Digital signature
Url : /lists/gimp-docs/attachments/20081101/2cdb1be7/attachment-0001.bin
Message: 4 Date: Sat, 01 Nov 2008 19:07:21 +0100 From: Sven Neumann
Subject: Re: [Gimp-docs] PDF version of help documentation To: "Phillip M. Feldman"
Cc: gimp-docs@lists.XCF.Berkeley.EDU Message-ID:
THat is not correct. The configure script looks for a GIMP installation only to find out where to install the help files. You can easily skip that check by passing --without-gimp to the configure script.
Roman Joost
2008-11-05 13:33:17 UTC (over 16 years ago)
Hi David,
That would mean capturing a lot (and I mean *a lot*) of localized screenshots for the manual. The amount of screenshots is already huge.
It would be much more helpful if you can help on translating the manual. What do you think?
Cheers,
