Snapping options should be remembered across sessions
Snapping options should be remembered across sessions Alexandre Prokoudine 01 Nov 19:29
  Snapping options should be remembered across sessions David Gowers 01 Nov 22:36
   Snapping options should be remembered across sessions Alexandre Prokoudine 01 Nov 22:52
    Snapping options should be remembered across sessions David Gowers 01 Nov 23:11
2008-11-01 19:29:26 UTC (over 16 years ago)
As requested to discuss it on list rather than on bgo...
It would be quite useful to be able using same snapping options (snapping to guides, grid, canvas border, active path) across sessions, preferably by defining defaults via "Edit - Preferences - Image Windows/Appearance" like UI.
I'm not sure which "tab" exactly it could be. Probably inside "Image Windows" group or after "Default Grid".
Alexandre
David Gowers
2008-11-01 22:36:34 UTC (over 16 years ago)
What exactly are you trying to propose here that is not included in the functionality of "Edit - Preferences - Image Windows/Appearance" itself?
Are you trying to say 'remember the options that a particular image has, across sessions'?
I'm baffled.
-- David
2008-11-01 22:52:04 UTC (over 16 years ago)
David, if you take time to actually read what is written above, you'll see that it says "snapping options", not "Show rulers" or "Show layer boundary". Believe me, there *is* a difference :)
Alexandre
David Gowers
2008-11-01 23:11:05 UTC (over 16 years ago)
Oh, I thought we had that already. Apparently not.
David
