PDF version of help documentation
10 of 10 messages available
PDF version of help documentation Phillip M. Feldman 01 Nov 17:05
  PDF version of help documentation Roman Joost 01 Nov 18:38
  PDF version of help documentation Sven Neumann 01 Nov 19:07
   PDF version of help documentation Phillip M. Feldman 03 Nov 06:15
    PDF version of help documentation Charlie Albright 03 Nov 09:22
     PDF version of help documentation Roman Joost 03 Nov 12:44
      PDF version of help documentation Axel Wernicke 03 Nov 17:59
    PDF version of help documentation Sven Neumann 04 Nov 23:16
PDF version of help documentation Mark Beihoffer 01 Nov 20:35
  PDF version of help documentation Sven Neumann 04 Nov 21:49
Phillip M. Feldman
2008-11-01 17:05:28 UTC (over 16 years ago)
The current help system requires that GIMP be installed first. It would be great if one could simply download a PDF file, with no dependence between the documentation and the GIMP software.
Phillip M. Feldman
Roman Joost
2008-11-01 18:38:39 UTC (over 16 years ago)
Hi Phillip,
we provide PDF builts of the documentation. Though they're currently a bit outdated, but we will update them as soon as possible.
You can find them at:
http://docs.gimp.org/download.html
Greetings,
2008-11-01 19:07:21 UTC (over 16 years ago)
THat is not correct. The configure script looks for a GIMP installation only to find out where to install the help files. You can easily skip that check by passing --without-gimp to the configure script.
Mark Beihoffer
2008-11-01 20:35:33 UTC (over 16 years ago)
So, I'd still really like the help files installed correctly with the gimp on OpenBSD. A PDF version would be acceptable, but I'd prefer the help file to compile and install correctly under OpenBSD.
OpenBSD 4.4 shipped today, so perhaps now is the time to create a port or package for OpenBSD 4.5? It will be out in six months, which should be plenty of time.
I'd be happy to help in any way I can.
Thanks,
- Mark Beihoffer
On Sat, Nov 1, 2008 at 2:00 PM, wrote:
Send Gimp-docs mailing list submissions to gimp-docs@lists.XCF.Berkeley.EDU
To subscribe or unsubscribe via the World Wide Web, visit https://lists.XCF.Berkeley.EDU/mailman/listinfo/gimp-docs or, via email, send a message with subject or body 'help' to gimp-docs-request@lists.XCF.Berkeley.EDU
You can reach the person managing the list at gimp-docs-owner@lists.XCF.Berkeley.EDU
When replying, please edit your Subject line so it is more specific than "Re: Contents of Gimp-docs digest..."
Today's Topics:
1. Re: Installing GIMP help files (Sven Neumann) 2. PDF version of help documentation (Phillip M. Feldman) 3. Re: PDF version of help documentation (Roman Joost) 4. Re: PDF version of help documentation (Sven Neumann)
Message: 1 Date: Fri, 31 Oct 2008 21:06:39 +0100 From: Sven Neumann
Subject: Re: [Gimp-docs] Installing GIMP help files To: Roman Joost
Cc: GIMP Docs
Message-ID:
Content-Type: text/plain
On Fri, 2008-10-31 at 14:57 +0100, Roman Joost wrote:
But on a second thought and a check at the Makefile I think we never released the manual as pre-built HTML files
I am very sure that the build system was initially designed to distribute pre-built HTML files. And I am also sure that this used to be done at some point in history. The installation instructions for the user manual still clearly state this.
Message: 2 Date: Sat, 01 Nov 2008 09:05:28 -0700 From: "Phillip M. Feldman"
Subject: [Gimp-docs] PDF version of help documentation To: gimp-docs@lists.XCF.Berkeley.EDU Message-ID:
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Phillip M. Feldman
Message: 3 Date: Sat, 1 Nov 2008 18:38:39 +0100 From: Roman Joost
Subject: Re: [Gimp-docs] PDF version of help documentation To: GIMP Docs
Message-ID:
Content-Type: text/plain; charset="utf-8"
Hi Phillip,
Greetings, --
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
-------------- next part -------------- A non-text attachment was scrubbed... Name: not available
Desc: Digital signature
Url : /lists/gimp-docs/attachments/20081101/2cdb1be7/attachment-0001.bin
Message: 4 Date: Sat, 01 Nov 2008 19:07:21 +0100 From: Sven Neumann
Subject: Re: [Gimp-docs] PDF version of help documentation To: "Phillip M. Feldman"
Cc: gimp-docs@lists.XCF.Berkeley.EDU Message-ID:
Phillip M. Feldman
2008-11-03 06:15:04 UTC (over 16 years ago)
When I invoke the installation program from the command line, I get exactly the same error message whether I include the "--without-gimp" option or not.
Phillip
Charlie Albright
2008-11-03 09:22:16 UTC (over 16 years ago)
why not just have a wiki (a la wikipedia) for all the help documentation? plus also links to youtube tutorials would be good as well Charles
--- On Mon, 11/3/08, Phillip M. Feldman wrote:
Subject: Re: [Gimp-docs] PDF version of help documentation To: "Sven Neumann"
Cc: gimp-docs@lists.XCF.Berkeley.EDU Date: Monday, November 3, 2008, 4:15 PM Hello,
option or not.
Phillip
installed first
GIMP installation
can easily skip
script.
Roman Joost
2008-11-03 12:44:20 UTC (over 16 years ago)
Hi Charles,
it's not that simple. This topic was already debated back and forth long ago. I remember that Axel Wernicke worked on a wiki solution.
I just can count several issues:
- migrating the current source to a wiki - creating HTML snapshots for the GIMP help system with stable ids - creating sane layouted printouts - spam problems and access restrictions
Though my position doesn't mean that a wiki is an impossible solution for the user manual.
Cheers,
Axel Wernicke
2008-11-03 17:59:25 UTC (over 16 years ago)
there still is a "private" GIMP-docs wiki playground at http://lexaikon.dnsalias.org/~medius/mediawiki/index.php/Main_Page containing the gimp manual from a few months ago.
Feel free to get the idea...
lexA
Am 03.11.2008 um 12:44 schrieb Roman Joost:
Hi Charles,
Cheers,
2008-11-04 21:49:05 UTC (over 16 years ago)
Then please do whatever fixes the build needs and send us a patch.
2008-11-04 23:16:27 UTC (over 16 years ago)
I've just verified that the configure option is still there and works as advertized. No check for GIMP is made if you pass --without-gimp to the configure script.
