Strange zoomout behavior
5 of 9 messages available
490862E6.5050201@cb-compute... 07 Oct 20:27
  Strange zoomout behavior Martin Nordholts 31 Oct 08:32
20173793.post@talk.nabble.com 07 Oct 20:27
4907653F.1010407@gmail.com 07 Oct 20:27
490AFF98.4020007@cb-compute... 07 Oct 20:27
  Strange zoomout behavior Martin Nordholts 02 Nov 08:51
   Strange zoomout behavior Martin Nordholts 15 Nov 11:38
    Strange zoomout behavior Claus Berghammer (Bugzilla) 15 Nov 13:25
    Strange zoomout behavior Claus Berghammer (Bugzilla) 25 Nov 11:55
Martin Nordholts
2008-10-31 08:32:59 UTC (about 17 years ago)
This is a reply to:
http://lists.xcf.berkeley.edu/lists/gimp-user/2008-October/013230.html
Hi
Claus Berghammer (Bugzilla) wrote:
I'm not shure if it is the same. I don't have "Resize window on zoom" and "Resize window on image size
change" enabled, nor do I use the crop tool, as it is described in #555493. But the result is comparable (but not the exactly the SAME).
Can you provide a detailed step-by-step on how to reproduce the problem please?
Using "Minus Key" is slow, because I have to type it several times, until I reach 100%. Using "Zoom Revert" doesn't do it either, because it also don't sends me back to 100%.
Where zoom revert takes you depend entire on your workflow. I admit that it might not be very pleasant to make sure Zoom Revert always goes back to 100% though.. I do however find it reasonable to zoom out with the - key if you want to use the cursor as zoom focus point, or you can maybe even just do a View -> Fit Image in Window. We can't tailor the zoom behaviour for a specific use case, it needs to be general.
And shall I write my arguments for a zoom operator key again into Bug 553534 (centering issues after image scaling and setting zoom to 100%)?
Again, I don' think a modifier key is a good idea.
BR, Martin
Martin Nordholts
2008-11-02 08:51:48 UTC (about 17 years ago)
Strange zoomout:
I attached a picture that shows all steps to reproduce (I hope attachments are O.K. on this list?):
I have to admit that that is a use case that should work. I think it's possible to make that use case work without breaking other use cases. I'll see what I can do.
BR,
Martin
Martin Nordholts
2008-11-15 11:38:03 UTC (almost 17 years ago)
Strange zoomout:
BR,
Martin
This is now fixed in trunk and gimp-2-6 and GIMP will behave as expected for your use case (the fix will be available in GIMP 2.6.3):
2008-11-15 Martin Nordholts
Bug 560903 – Explicit zooming with e.g. '1' should handle zoom-focus better
* app/display/display-enums.h: Added GIMP_ZOOM_FOCUS_RETAIN_CENTERING_ELSE_BEST_GUESS.
* app/display/gimpdisplayshell-scale.c (gimp_display_shell_scale_get_zoom_focus): Take the new enum into account; if the image is centered, keep it centered, else use the best-guess method.
* app/actions/view-commands.c (view_zoom_explicit_cmd_callback): Use the new enum for explicit zooming.
* app/display/display-enums.c: Regenerated.
BR. Martin
2008-11-15 13:25:51 UTC (almost 17 years ago)
Thanks for your fix. Can't wait for 2.6.3 to test it...
Claus
Strange zoomout:
BR,
Martin
BR. Martin
2008-11-25 11:55:13 UTC (almost 17 years ago)
Tested with 2.6.3 for Windows, and Zoom Out is working like a charm now again ;-)
Thanks to Martin Nordholts, and all other developers...
BR, Claus
Strange zoomout:
BR,
Martin
BR. Martin
