Installing GIMP help files
Installing GIMP help files Mark Beihoffer 27 Oct 20:20
  Installing GIMP help files Sven Neumann 28 Oct 08:06
   Installing GIMP help files Mark Beihoffer 28 Oct 18:33
    Installing GIMP help files Sven Neumann 29 Oct 07:53
     Installing GIMP help files Roman Joost 31 Oct 14:57
      Installing GIMP help files Sven Neumann 31 Oct 21:06
Mark Beihoffer
2008-10-27 20:20:26 UTC (over 16 years ago)
I've been trying to install the GNU Image Manipulation Program help files on OpenBSD 4.3 for a while now, and no luck.
In most other distributions the help files are a separate package, but there is no OpenBSD package for them and nothing in the ports tree.
I downloaded the help files from ftp://ftp.gimp.org/pub/gimp/help/ as recommended by http://www.gimp.org/downloads/ and extracted the bzip2 files, then tried to follow the INSTALL document.
./configure
checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... ./install-sh -c -d checking for gawk... no
checking for mawk... no
checking for nawk... nawk
checking whether make sets $(MAKE)... yes checking for a BSD-compatible install... /usr/bin/install -c checking whether ln -s works... yes
checking whether make sets $(MAKE)... (cached) yes checking whether make is GNU make... configure: error: make not found
I installed gmake from packages and tried again, and it still couldn't find GNU make. There is nothing in the README or the INSTALL file that indicates I can set a flag to locate make during configuration.
What should I do?
Thanks,
- Mark Beihoffer http://www.dragonfly-networks.com
2008-10-28 08:06:00 UTC (over 16 years ago)
What should I do?
You don't really need make as the package you downloaded already contains everything pre-built. Just copy the folder with the HTML files and images to the right location. The right location is share/gimp/2.0/help in the prefix of your GIMP installation.
Mark Beihoffer
2008-10-28 18:33:42 UTC (over 16 years ago)
Thanks for the response - unfortunately, this did not work for me.
I've tried to locate the HTML files, but all the files in the package I downloaded are XML files, not HTML files.
Copying the /src directory to /usr/local/share/gimp/2.0/help did not work - any other suggestions?
Thanks in advance.
- Mark Beihoffer
What should I do?
2008-10-29 07:53:40 UTC (over 16 years ago)
I am sorry, it looks like the content of the help package changed and I did not notice this change.
This is pretty bad. We used to ship pre-built HTML files in the release tarballs. The installation instructions in the file INSTALL also still refer to this situation. So they are pretty much wrong now. Roman, is this an intentional change? Shouldn't at least INSTALL be adjusted then?
Roman Joost
2008-10-31 14:57:04 UTC (over 16 years ago)
sorry for not replying earlier. Just had a teeth surgery and need a bit of time to relax.
Actually I'm puzzled. Because the last release also haven't had any pre-built HTML files and on a first thought I'm very sorry of this.
But on a second thought and a check at the Makefile I think we never released the manual as pre-built HTML files, but always as a source release. The reason for doing is because the distributors always created their own packages, seperated by languages.
That's why I'm kind of confused. The past releases (prior to 2.4.1) are made one year ago and I can't say for sure how we did it. The built system changed to often ...
I'll investigate this further soon as I'm feeling confortable.
As for the situation of Mark currently have: either we fix the built-system and do another release of the 2.4.2 tag or we fix the built-system to support OpenBSD (probably faster).
Greetings,
2008-10-31 21:06:39 UTC (over 16 years ago)
I am very sure that the build system was initially designed to distribute pre-built HTML files. And I am also sure that this used to be done at some point in history. The installation instructions for the user manual still clearly state this.
