Temporary lockup bug with 'resize canvas'?
Temporary lockup bug with 'resize canvas'? David Gowers 27 Oct 00:05
David Gowers
2008-10-27 00:05:48 UTC (over 16 years ago)
With a recent SVN build of GIMP, I noticed that after entering a new size in the 'Resize Canvas' dialog, the dialog would not show the new size, and became unresponsive until I moved the window -- then it would show the new size and respond to input.
To be exact, I did this: 1. Bring up the 'resize canvas' dialog 2. Unchain the width and height
3. Type a new number in the width field and hit Return
NOTE: This bug only occurs when the width and height are unchained; When they are unchained, you can trigger the bug by modifying either width or height and hitting Return.
This bug also occurs in the similar 'layer boundary size' dialog, triggered in the exact same way. It does not occur with scaling dialogs.
I'm using AwesomeWM 3.0 on Ubuntu 8.04, with recent SVN GTK and SVN GLib. Has anyone else encountered this?
