GEGL Developers
| GEGL Developers | Eric Grivel | 08 Jan 17:51 |
| GEGL Developers | Sven Neumann | 08 Jan 18:16 |
| GEGL Developers | Eric Grivel | 10 Jan 01:00 |
| GEGL Developers | Florent Monnier | 10 Jan 10:49 |
| GEGL Developers | Michael Schumacher | 10 Jan 11:36 |
| GEGL Developers | Eric Grivel | 18 Jan 03:35 |
GEGL Developers
I'm a software developer by profession, and amateur photographer. I love using GIMP and was looking for a way to contribute to the development of a 16-bit version of that tool. The GIMP Bugzilla has an entry (#74224) which seems to track this enhancement, and it refers to "gegl", so I figure that would be the place to start.
I went to gegl.org, downloaded the code (got it to compile), looked at the FAQ and the archive for this month of the mailing list... and found that I have no clue about what is going on and whether or how I would be able to contribute.
So my questions: - Is gegl the right place to contribute to a 16-bit version of Gimp? - Is this mailing list the right place to talk about gegl? - Is development going on that I could participate in? - Is there a place to find an overview, or someone who can give me an overview, of what gegl is about? I'm an experienced C programmer, but know next to nothing about graphics theory.
If this is the right place, and if I can make a serious contribution, I'm willing to try and spend some time on learning whatever I need to learn. However, I'm going to need some help to get started; just looking at the source code is not going to get me anywhere here.
Best, Eric
GEGL Developers
Eric Grivel writes:
Yes.
Yes.
Development happens in irregular intervals whenever someone finds the time and motivation for it. Last summer an effort was made to clean up the source code and to identify missing pieces. Pippin has since then developed babl, a library for color conversion that is waiting to be used from gegl. The most important missing piece at the moment is the code to actually store the image data. As soon as we have that, gegl would for the first time become actually useful and we can consider to start using it from GIMP.
GEGL Developers
As I mentioned before, I have quite a lot of experience in C programming (and other languages, for that matter), but zero in open source development and/or graphics. I think I might be able to make a contribution, but need someone to help me get started.
Is there some interface defined that needs implementing? Is this about saving an image to a file, or the internal in-memory storing? What are the relevant data structures? Or, in other words, where to start?
Best, Eric
GEGL Developers
Open source projects are most the time coordinated through CVS (or CVS like
systems).
But before to get a CVS access the maintainers of it prefer to see the
quatlity of the contributions made by someone to prevent the CVS tree
database to be corrupted, like a Wiki can be when everyone can write in it.
So the first contribution are most often send as patch (man diff, man patch).
Make your patch with the command 'diff -U 5 src.c.orig src.c' on the very last
version of the file which you just got through cvs.
I am not experienced in C programming at all, just a c beginner as a hobby :), I'm infographist and i've learn to program to be able to get in the sources of the tools I use because there are often ergonomics choices I would like to change.
If you want to introduce smoothly yourself to graphics programming there is a
very good tutorial made by Pippin:
http://pippin.gimp.org/image_processing/
Perhaps you're too experienced for this introduction, but for me it was just
perfect!
You could also have a look at IM and GM, to see how they store and process
image data.
http://www.graphicsmagick.org/
http://www.imagemagick.org/
It is possible to choose the number of bits used for pixel values before
compiling with ./configure --with-quantum-depth 16.
The default is 8 bits for GM and 16 bits for IM.
The default range of IM is 0 < 65535, in Gimp it seems to be 0 < 255 I think.
But to use IM on a web-server perhaps it is a beter idea to compile it in
depth 8, I'm not sure.
IM is integrated with PHP trough php_imagick, and on Debian it seems that the
default quantum 16 has been keept.
As you said you "was looking for a way to contribute to the development of
a 16-bit version of that tool", maybe the IM technical choices to switch on
this could interest you.
But before to make an equivalent implementation for Gegl, perhaps you should
ask to the Gegl leader which implementation should be choosen.
I don't remember if there are things around 8/16 bits in pippin's gggl.
Here the Gegl gurus would be more appropriate to answer ;-)
GEGL Developers
Von: Florent Monnier
... and are preferably attached to a report in Bugzilla.
"send" implies email, and this would be a good way to have your contributions lost in a crowded mailbox.
HTH, Michael
GEGL Developers
Yeah, I can give you a call and talk about it. Email me privately with your number. I have a good outline as to where to go, and what to do next. Just no time to work on it.
I did email you a couple of days ago, but I've had some problem with my lumenssolutions.com email recently, so your answer may have been lost.
I would prefer to use email rather than phone for most communications. I can only work on Gegl in my spare time, and we tend to go to bed rather early.
Thanks,
Eric
