Feature request, include filename with curves autosave
Feature request, include filename with curves autosave Kent Tenney 09 Oct 20:47
  Feature request, include filename with curves autosave David Gowers 10 Oct 00:47
   Feature request, include filename with curves autosave Kent Tenney 14 Oct 14:28
Kent Tenney
2008-10-09 20:47:47 UTC (over 16 years ago)
Howdy,
I wish the gimp-curves-tool.settings file, which contains sections starting with:
(GimpCurvesConfig "2008-10-03 14:34:26" (time 1223062466)
(channel value)
(curve
also listed the name of the file (or 'unnamed')
fully qualified would be great, bare would be fine.
Thanks, Kent
David Gowers
2008-10-10 00:47:43 UTC (over 16 years ago)
On Fri, Oct 10, 2008 at 5:17 AM, Kent Tenney wrote:
Howdy,
(channel value)
(curve
This is the name of the file:
ie. no file (the only completely-accurate preservation of the curve is in the gimp-curves-tool.settings file, and unless you've explicitly exported it, no other file will contain data on that curve.) Or were you asking for a list of filenames that this curve has been exported as?
Thanks, Kent
HTH,
David
Kent Tenney
2008-10-14 14:28:46 UTC (over 16 years ago)
Howdy,
(channel value)
(curve
I guess I'm unclear, an example;
I adjust curves on that file.
The description of the adjustment is written to gimp-curves-settings.
I would like to see the following in gimp-curves-settings (GimpCurvesConfig "2008-10-03 14:34:26" (time 1223062466)
(file DSCN001.jpg)
(channel value)
(curve
If this is possible, it would allow me to match the required adjustment with the image file. I could then write scripts which applied this correction.
Does that make sense?
Thanks, Kent
Thanks, Kent
HTH,
David
Everything has reasons. Nothing has justification. ?io havas kialojn; Nenia?o havas pravigeron.
