Define a key short cut from a plugin
Define a key short cut from a plugin Nicolás Serrano Martínez Santos 02 Oct 17:35
  Define a key short cut from a plugin Sven Neumann 02 Oct 20:46
2008-10-02 17:35:30 UTC (over 16 years ago)
Hi! Is it possible to define a shortcut for a plugin inside it's code? For instance I want that my plug-in is associated with "Crtl + Alt + f" automatically when installing it. Now I have to do it using the Keybinding option at the Gimp Toolbox. Would I have to parse the .gimp-2.4/menurc file manually?
Thanks!
2008-10-02 20:46:21 UTC (over 16 years ago)
No, there's no API that would allow plug-ins to do this. And I don't think we want to add such API.
