ANNOUNCE: GIMP 2.6.1
ANNOUNCE: GIMP 2.6.0 | Sven Neumann | 01 Oct 20:56 |
ANNOUNCE: GIMP 2.6.0 | Etienne lepercq | 01 Oct 21:58 |
ANNOUNCE: GIMP 2.6.0 | Brendan | 02 Oct 00:33 |
Built-in help (was: ANNOUNCE: GIMP 2.6.0) | Alec Burgess | 03 Oct 07:58 |
Built-in help | Sven Neumann | 03 Oct 14:02 |
Built-in help | Hans Breuer | 03 Oct 14:49 |
Built-in help | Tor Lillqvist | 03 Oct 15:50 |
Built-in help | Hans Breuer | 03 Oct 16:44 |
Built-in help | Hans Breuer | 03 Oct 19:37 |
Built-in help | Sven Neumann | 03 Oct 20:21 |
Built-in help | Hans Breuer | 03 Oct 21:30 |
ANNOUNCE: GIMP 2.6.0 | Werner F. Bruhin | 02 Oct 09:45 |
ANNOUNCE: GIMP 2.6.0 | Alessandro Falappa | 02 Oct 11:10 |
ANNOUNCE: GIMP 2.6.0 | Alexia Death | 02 Oct 13:04 |
ANNOUNCE: GIMP 2.6.1 | Sven Neumann | 09 Oct 22:23 |
ANNOUNCE: GIMP 2.6.1 | tks | 10 Oct 02:49 |
ANNOUNCE: GIMP 2.6.1 | Sven Neumann | 12 Oct 16:30 |
ANNOUNCE: GIMP 2.6.1 | tks | 12 Oct 19:13 |
Finally we have done it and released version 2.6.0 of the GNU Image Manipulation Program. The changes from version 2.4 are best described in the release notes on
http://gimp.org/release-notes/gimp-2.6.html
If you want to compile GIMP 2.6 yourself, you can grab the tarball from ftp.gimp.org or one of its mirrors:
ftp://ftp.gimp.org/pub/gimp/v2.6/
Please note that there was a glitch in the 2.6.0 tarball on the FTP server that was corrected after a few hours. If in doubt, you can use the following information to check that you have the fixed tarball:
filename: gimp-2.6.0.tar.bz2
MD5 sum: e5ac955fee8b376d431e4693027d7640
Binary packages for the various supported platforms are expected to become available over the next couple of days. The new gimp.org website will help you to locate the packages for your system:
Thanks a lot to everyone who helped to improve GIMP.
2008/10/1 Sven Neumann
filename: gimp-2.6.0.tar.bz2 size: 15897821 bytes
MD5 sum: e5ac955fee8b376d431e4693027d7640Binary packages for the various supported platforms are expected to become available over the next couple of days. The new gimp.org website will help you to locate the packages for your system:
I just want to say congrats to everyone here, for their work... you are talented people dedicated to a beautiful - and very useful - project. I read every day mails of the gimp-dev ML, and admire many people here !
So, have a nice, sweet week... before working on 2.8 ? ;-)
Looks great!
Thanks for providing such a neat tool!
BTW, the downloads page link below is still pointing to the 2.4.7 version.
Werner
Congratulations to the whole GIMP Team. It looks like this will be a fantastic release: it shows great improvements and the changes "under the hood" will make the user excited about the future.
Kudos everyone.
It seems to be making people overly excided and jumping to conclusions generating anti-FUD. GIMP still only supports 8bits per channel. The day of GEGL based gimp is not today and most likely wont be 2.8 release date either. The integration will take time.
...Congratulations to the whole GIMP Team. It looks like this will be a fantastic release: it shows great improvements and the changes "under the hood" will make the user excited about the future.
Kudos everyone.
-- Alessandro Falappa
web: http://www.falappa.net/_______________________________________________ Gimp-developer mailing list
Brendan (mailinglist@endosquid.com) wrote (in part) (on 2008-10-01 at 18:33):
the release notes on http://gimp.org/release-notes/gimp-2.6.html
In those notes it says:
Minor Changes : Added support for using online help instead of a
locally installed GIMP Help package.
I installed the Windows 2.6.0 build gimp-2.6.0-i686-setup-1.exe, ran it, closed it then installed gimp-help-2-2.4.0-eng-setup.exe (it identified the location I had put GIMP 2.6)
In Preferences I set: Help system to "user manual: Use locally installed copy" (text below says "There's a local installation of the user manual" and Help browser to use: Gimp help browser.
If I click on the [Help] button on the preferences pane (or any where else attempt [F1] or Shift+F1) I get popup warning:
The GIMP help browser plug-in appears to be missing from your
installation.
You may instead use the web browser for reading the help pages.
Clicking [Use Web Browser] changes parameter "Help browser to use:" to "Web browser" but does NOT open anything in my default browser (Portable Firefox 3)
I assume this is user-setup-error and would normally request help in gimp-users or gimpwin-users but since release is so recent thought I'd ask here.
Built-in help
The code that opens the default web-browser on Windows seems to work fine for some users, and fails for others. It would be nice if someone who knows the Win32 API could have a look at this code and try to fix it. But given the fact that there is hardly any contributions from users and developers on Windows, I don't expect this to happen ever...
Built-in help
Sorry to here that :) By coincidence I have built the GIMP from trunk on windows recently (patches pending). I'm getting:
help.exe-Warning: Could not open 'http://docs.gimp.org/2.4/en/gimp-help.xml' for reading: Operation not supported
Perhaps you are missing GIO backends and need to install GVFS?
So my guess is: at least for 2.6 this is not working for any of the windows users. As far as I know there is no GIO/win32 backend which supports http.
But it should be relatively easy to restore the old win32 specific code which used ShellExecute() to open links. That should make the web-browser work for every windows user with a properly configure system.
Hans
-------- Hans "at" Breuer "dot" Org ----------- Tell me what you need, and I'll tell you how to get along without it. -- Dilbert
Built-in help
Http is supported in libgio itself (using the winhttp API from winhttp.dll, which is looked up at run-time, so if you lack that, it won't work). See gio/win32/gwinhttp*.c.
--tml
Built-in help
The DLL is available on my computer (xp sp3), but my GLIB version is just one week too old (beginning of August).
Built-in help
With a new enough gio it indeed works fine. I have also tried the GIMP with Jerney's installer under vista, same here: it just works for me.
Afterwards I have intentional broken the code in web-browser.c (with: url++;). When ShellExecute() failed there indeed was no error message at all.
The attached patch fixes this, but also adds a lot of hard to translate strings. Should it be commited ?
Index: web-browser.c
--- web-browser.c (revision 27115)
+++ web-browser.c (working copy)
@@ -120,9 +120,61 @@
browser_open_url (const gchar *url)
#ifdef G_OS_WIN32
+ HINSTANCE hinst = ShellExecute (GetDesktopWindow(), "open", url, NULL, NULL, SW_SHOW);
+ if ((gint) hinst 32);
+ return TRUE;
#else
GError *error = NULL;
Built-in help
We shouldn't add new translatable messages at this point. Could you commit this to trunk without the error messages marked for translation? We can then remark them for translation after we branched and after the strings have been reviewed.
Built-in help
Done:
2008-10-03 Hans Breuer
* plug-ins/common/web-browser.c : when ShellExecute() is failing give the detailed (currently intentionally untranslated) error message via g_message()
GIMP 2.6.1 is a bug-fix release in the stable GIMP 2.6 series. The source can be downloaded from ftp.gimp.org or one of the mirrors listed at http://gimp.org/downloads/#mirrors
Binary packages for the various supported platforms should become available soon; please check the Downloads section on www.gimp.org. Rumours are that the 2.6.1 installer for Windows will include a version of GTK+ that has the utility window hint implemented, keeping the GIMP toolbox and docks above the image window and out of the taskbar.
Overview of Changes from GIMP 2.6.0 to GIMP 2.6.1 =================================================
* Bugs fixed:
555587 – PSD file crashes PSD plug-in 555222 – PSD Load Plugin: unsupported compression mode 555362 – gimp-remote is not working properly 555280 – some gif files will not be open 554890 – JPEG Save Options Dialog does not remember 554966 – Gimp crashes creating a new image using a template 554785 – Compile failure on uri-backend-libcurl 554646 – Opening Help crashes GIMP with lqr-plugin installed 553534 – centering issues after image scaling and setting zoom 554898 – Compile failure on uri-backend-wget.c
* Updated translations:
Belarusian (be)
Catalan (ca)
Finnish (fi)
French (fr)
Japanese (ja)
Macedonian (mk)
Punjab (pa)
Brazilian Portuguese (pt_BR)
Romanian (ro)
Slovenian (sl)
Swedish (sv)
It seems that patch-2.6.1.bz2 includes patches for nonexistent files.
$ LANG=C md5sum -c patch-2.6.1.bz2.md5
patch-2.6.1.bz2: OK
$ bzcat patch-2.6.1.bz2 |patch -p0 --dry-run -f |fgrep 'find' -A4
can't find file to patch at input line 1559
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff -uraN gimp-2.6.0/app/gui/gimpdbusservice-glue.h
gimp-2.6.1/app/gui/gimpdbusservice-glue.h
can't find file to patch at input line 86822
|diff -uraN gimp-2.6.0/devel-docs/libgimpwidgets/xml/gimphruler.xml
gimp-2.6.1/devel-docs/libgimpwidgets/xml/gimphruler.xml
can't find file to patch at input line 86920
|diff -uraN gimp-2.6.0/devel-docs/libgimpwidgets/xml/gimpvruler.xml
gimp-2.6.1/devel-docs/libgimpwidgets/xml/gimpvruler.xml
can't find file to patch at input line 89061
|diff -uraN gimp-2.6.0/plug-ins/pagecurl/pagecurl-icons.h
gimp-2.6.1/plug-ins/pagecurl/pagecurl-icons.h
Do I take it wrong?
On Fri, 2008-10-10 at 09:49 +0900, tks wrote:
It seems that patch-2.6.1.bz2 includes patches for nonexistent files. $ LANG=C md5sum -c patch-2.6.1.bz2.md5 patch-2.6.1.bz2: OK
$ bzcat patch-2.6.1.bz2 |patch -p0 --dry-run -f |fgrep 'find' -A4 can't find file to patch at input line 1559 Perhaps you used the wrong -p or --strip option?
Just as the error message suggests, you are using the wrong -p option with the patch command. Please refer to the patch manual page or use the full tarball instead.
Hi , thank you for reply.
I don't think so.
What I exactly meant in last post is that patch-2.6.1.bz2 includes
patches for these four files
app/gui/gimpdbusservice-glue.h devel-docs/libgimpwidgets/xml/gimphruler.xml devel-docs/libgimpwidgets/xml/gimpvruler.xml plug-ins/pagecurl/pagecurl-icons.h
but they are not in src tarballs of 2.6.0. (and 2.6.1 too) So I don't know what these files are ,yet I think they are unwanted.
Anyway It's not critical, I patched successfully by ignoring these four parts before last post and there is nothing problem for me now.
thanks.
