GEGL making failed
GEGL making failed Cédric Gémy 17 Sep 14:00
  GEGL making failed Kevin Cozens 18 Sep 15:36
   GEGL making failed Cédric Gémy 18 Sep 23:59
  GEGL making failed Sven Neumann 18 Sep 22:03
Cédric Gémy
2008-09-17 14:00:28 UTC (over 16 years ago)
GEGL making failed
Hello
Does anyone know what pb could cause this error ?
In file included from atop.c:21: ../../gegl/gegl-chant.h:26:2: error: #error "GEGL_CHANT_C_FILE not defined"
../../gegl/gegl-chant.h:310: error: expected ‘)’ before ‘*’ token ../../gegl/gegl-chant.h:359:10: error: #include expects "FILENAME" or
../../gegl/gegl-chant.h:392:10: error: #include expects "FILENAME" or
../../gegl/gegl-chant.h: In function ‘get_property’: ../../gegl/gegl-chant.h:416: error: dereferencing pointer to incomplete type
../../gegl/gegl-chant.h:465:10: error: #include expects "FILENAME" or
../../gegl/gegl-chant.h: In function ‘set_property’: ../../gegl/gegl-chant.h:492: error: dereferencing pointer to incomplete type
../../gegl/gegl-chant.h:559:10: error: #include expects "FILENAME" or
../../gegl/gegl-chant.h: In function ‘gegl_chant_destroy_notify’: ../../gegl/gegl-chant.h:581: error: dereferencing pointer to incomplete type
../../gegl/gegl-chant.h:630:10: error: #include expects "FILENAME" or
../../gegl/gegl-chant.h:760:10: error: #include expects "FILENAME" or
../../gegl/gegl-chant.h: In function ‘gegl_chant_init_properties’: ../../gegl/gegl-chant.h:779: error: dereferencing pointer to incomplete type
pygmee
Kevin Cozens
2008-09-18 15:36:36 UTC (over 16 years ago)
GEGL making failed
The atop.c file isn't part of the GEGL source. It would help if you posted the source somewhere. You are probably missing some include file, missing a #define, or have a syntax error in the top part of the file.
2008-09-18 22:03:10 UTC (over 16 years ago)
GEGL making failed
On Wed, 2008-09-17 at 12:00 +0000, Cédric Gémy wrote:
Hello
The problem is that some files in GEGL are autogenerated. And there are no proper Makefile rules for this step. Instead they are generated when you run autogen.sh. So, unlike in other projects, in GEGL you may have to rerun autogen.sh after you updated your source tree. It would certainly be nice if someone could fix this.
Cédric Gémy
2008-09-18 23:59:10 UTC (over 16 years ago)
GEGL making failed
make distclean and recheckout everything has been enough, thanks for you help.
pygmee
