Problems occurs when executing ./autogen.sh
7 of 7 messages available
Problems occurs when executing ./autogen.sh XuHunt 16 Sep 09:00
  Problems occurs when executing ./autogen.sh Bill Skaggs 16 Sep 18:25
   Problems occurs when executing ./autogen.sh Sven Neumann 16 Sep 19:16
  Problems occurs when executing ./autogen.sh Sven Neumann 16 Sep 19:01
   Problems occurs when executing ./autogen.sh Roman Joost 17 Sep 09:10
  Problems occurs when executing ./autogen.sh Sven Neumann 16 Sep 19:19
   Problems occurs when executing ./autogen.sh XuHunt 17 Sep 07:10
XuHunt
2008-09-16 09:00:12 UTC (over 16 years ago)
[hunt@bubble ~/hunt's/gimp-docs/gimp-help-2]$ O_< ./autogen.shLooking for latest automake version ... 1.10I am going to run ./configure with the following arguments: --enable-maintainer-mode --enable-build If you wish to pass additional arguments, please specify them on the ./autogen.sh command line or set the AUTOGEN_CONFIGURE_ARGS environment variable.Makefile.am:437: user target `.PRECIOUS' defined here.../usr/share/automake-1.10/am/configure.am: ... overrides Automake target `.PRECIOUS' defined hereconfigure: WARNING: unrecognized options: --enable-maintainer-modechecking for a BSD-compatible install... /bin/install -cchecking whether build environment is sane... yes./configure: eval: line 1979: unexpected EOF while looking for matching `''./configure: eval: line 1980: syntax error: unexpected end of fileconfigure: WARNING: `missing' script is too old or missingchecking for a thread-safe mkdir -p... /bin/mkdir -pchecking for gawk... gawkchecking whether make sets $(MAKE )... yeschecking for a BSD-compatible install... /bin/install -cchecking whether ln -s works... yeschecking whether make sets $(MAKE)... (cached) yeschecking whether make is GNU make... yeschecking for xsltproc... /usr/bin/xsltprocchecking for xmllint... /usr/bin/xmllintchecking for dblatex... noconfigure: WARNING: cannot find dblatex(1), PDF generation disabledchecking for docbook2odf... noconfigure: WARNING: cannot find docbook2odf(1), ODF generation disabledchecking for xml2po... noconfigure: WARNING: cannot find xml2po(1), SVG generation disabled(this tool is part of the gnome-doc-utils package)checking for pkg-config... /usr/bin/pkg-configchecking pkg-config is at least version 0.9.0... yeschecking for GIMP... yesconfigure: creating ./config.status./config.status: line 390: syntax error near unexpected token `)'./config.status: line 390: ` *\'*) ac_optarg=`$as_echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"` ;;'Configure failed or did not finish!What are the requirements
to build the gimp-docs? How should I deal with the problem above?P.S.:Usually I prefer make pdf to check my effort. __________________
Bill Skaggs
2008-09-16 18:25:07 UTC (over 16 years ago)
2008/9/16 XuHunt :
[hunt@bubble ~/hunt's/gimp-docs/gimp-help-2]$ O_< ./autogen.sh Looking for latest automake version ... 1.10
? --enable-maintainer-mode --enable-build ?
It looks to me like the problem is the --enable-maintainer-mode argument. That's
a valid argument to "configure", but not to "autogen.sh". The autogen script supplies that argument automatically when it runs configure.
-- Bill
2008-09-16 19:01:42 UTC (over 16 years ago)
If you wish to pass additional arguments, please specify them? on the ./autogen.sh command line or set the AUTOGEN_CONFIGURE_ARGS? environment variable.
Looks like someone removed AM_MAINTAINER_MODE from configure.ac. If that change was intentional, then autogen.sh needs to be adjusted. I rather suggest though that AM_MAINTAINER_MODE is added back.
2008-09-16 19:16:35 UTC (over 16 years ago)
On Tue, 2008-09-16 at 09:25 -0700, Bill Skaggs wrote:
It looks to me like the problem is the --enable-maintainer-mode argument. That's a valid argument to "configure", but not to "autogen.sh".
Any option that can be passed to configure can be safely passed to autogen.sh. The latter just passes them on.
2008-09-16 19:19:50 UTC (over 16 years ago)
we will need to have a look at the generated configure and config.status scripts in order to find out what went wrong on your system. Can you put these two files online somewhere?
XuHunt
2008-09-17 07:10:00 UTC (over 16 years ago)
http://paste.ubuntu.org.cn/9461config.status above.Just inform me if more information is needed.> Subject: Re: [Gimp-docs] Problems occurs when executing ./autogen.sh> From: sven@gimp.org> To: huntxu@live.cn> CC: gimp-docs@lists.xcf.berkeley.edu> Date: Tue, 16 Sep 2008 19:19:50 +0200> > Hi,> > we will need to have a look at the generated configure and config.status> scripts in order to find out what went wrong on your system. Can you put> these two files online somewhere?> > > Sven> > __________________
Roman Joost
2008-09-17 09:10:38 UTC (over 16 years ago)
Actually good question. I checked the revision log of the configure.ac file and since GNOME switched to SVN, no one removed this statement. I need to dig deeper I guess ...
Greetings,
