#defining the restrict keyword
4 of 5 messages available
28887367.54171221319085541.... 07 Oct 20:29
  #defining the restrict keyword Nicolas Robidoux 13 Sep 17:21
   #defining the restrict keyword Sven Neumann 16 Sep 08:14
    #defining the restrict keyword Nicolas Robidoux 16 Sep 15:11
     #defining the restrict keyword Nicolas Robidoux 16 Sep 17:27
Nicolas Robidoux
2008-09-13 17:21:18 UTC (about 17 years ago)
Hello Sven:
Given that the restrict keyword may be defined by default for other compilers than gcc (it is in gcc
http://developer.apple.com/documentation/DeveloperTools/gcc-4.0.1/gcc/Other-Builtins.html
wouldn't the following be better?
#ifndef restrict #ifndef G_GNUC_RESTRICT
#if defined (__GNUC__) && (__GNUC__ >= 4) #define G_GNUC_RESTRICT __restrict__ #else
#endif
#define restrict G_GNUC_RESTRICT
#endif
#endif
This appears to work in (the not yet patched in svn) yafr.
Even better:
It appears that autoconf can take care of this in one fell swoop:
http://www.gnu.org/software/libtool/manual/autoconf/C-Compiler.html
See the Macro: AC_C_RESTRICT section.
Nicolas Robidoux Laurentian University/Universite Laurentienne
2008-09-16 08:14:47 UTC (about 17 years ago)
#endif
#endif
#endif
Well, using plain "restrict" probably only works if C99 is enabled. And if C99 is enabled, then there's no need for this macro. So the easiest solution would certainly be to switch to C99 for GEGL.
Nicolas Robidoux
2008-09-16 15:11:36 UTC (about 17 years ago)
Hello:
Sven Neumann writes: > Hi,
> On Sat, 2008-09-13 at 11:21 -0400, Nicolas Robidoux wrote: >
> > Given that the restrict keyword may be defined by default for other compilers than gcc (it is in gcc > >
> > http://developer.apple.com/documentation/DeveloperTools/gcc-4.0.1/gcc/Other-Builtins.html > >
> > wouldn't the following be better? > >
> > #ifndef restrict
> > #if defined (__GNUC__) && (__GNUC__ >= 4) > > #define G_GNUC_RESTRICT __restrict__ > > #else
> > #endif
> > #define restrict G_GNUC_RESTRICT > > #endif
> > #endif
> Well, using plain "restrict" probably only works if C99 is enabled. And > if C99 is enabled, then there's no need for this macro. So the easiest > solution would certainly be to switch to C99 for GEGL. >
> Sven
I believe that restrict is understood by gcc UNLESS told not to (for example, with -ansi -pedantic). For example, if I put it in gegl-sampler-yafr.c without otherwise changing the make files, the code compiles no problem (whether gcc does something useful with it is another story).
In any case, the above macro will work with any compiler which does support the restrict keyword in whatever mode it is used (c99 ir not). In addition, it does not rely on B_GNUC_RESTRICT being defined to activate "restrict."
Of course, switching to c99 makes this whole discussion irrelevant.
Nicolas Robidoux
2008-09-16 17:27:21 UTC (about 17 years ago)
Ooops!
My last post was wrong:
gcc does not understand restrict by default. c99 needs to be turned on, restrict needs to be defined in terms of gcc extensions, or this needs to be take care of by autoconf.
Apologies,
