gimp print dlg
| gimp print dlg | gg@catking.net | 10 Sep 10:41 |
| gimp print dlg | Michael Schumacher | 10 Sep 10:54 |
| gimp print dlg | gg@catking.net | 10 Sep 11:07 |
| gimp print dlg | Akkana Peck | 10 Sep 19:16 |
| gimp print dlg | gg@catking.net | 10 Sep 22:22 |
| gimp print dlg | Robert Krawitz | 11 Sep 01:38 |
| gimp print dlg | Sven Neumann | 11 Sep 08:45 |
gimp print dlg
where does the current (cvs) print dlg come from. It looks the same as the one used by ffox so I guess it may be gtk+ rather than gimp.
Though it has many fancy features it lacks the simple on screen scaling and positioning that was so useful in gimpprint.
Is there a way to build recent gimp to use gimpprint/gutenprint plugin for printing? I don't see anything that seems to correcpond in ./configure options.
Thanks for any help on that.
regards.
gimp print dlg
Von: gg@catking.net
It is the other way round - you build gutenprint and tell it to create a gimp plug-in (if that isn't the default if it detects libgimp during configure, that is).
HTH, Michael
gimp print dlg
On Wed, 10 Sep 2008 10:54:55 +0200, Michael Schumacher wrote:
Von: gg@catking.net
HTH,
thanks for the explaination. I've checked and gimp-print is built with gimp option. Should that alter the dlg I get from gimp file print menu?
BTW gimp print preview just zaps out (I'll detail that in another post).
Thx
gimp print dlg
gg@catking.net writes:
Are you building in gimp-print then doing a make install?
Is this the latest gimp-print from
http://sourceforge.net/projects/gimp-print/ ?
Check that make install is really succeeding.
If you already have gimp's built-in gtkprint plug-in, and you also build gimp-print from the Gutenprint project, you'll probably end up with two different File->Print... menu entries. One of them should bring up the Gutenprint dialog, the other, the GTKprint one.
As long as you're building gutenprint yourself, I'd recommend modifying their src/gimp/print.c: find the line that registers to N_("/File/Print..."), (line 166 in the latest version) and change the name, e.g. N_("/File/GutenPrint..."),
Then you'll be able to tell the the two plug-ins apart and verify that your gutenprint plug-in is really getting installed.
...Akkana
gimp print dlg
Are you building in gimp-print then doing a make install? Is this the latest gimp-print from
http://sourceforge.net/projects/gimp-print/ ? Check that make install is really succeeding.If you already have gimp's built-in gtkprint plug-in, and you also build gimp-print from the Gutenprint project, you'll probably end up with two different File->Print... menu entries. One of them should bring up the Gutenprint dialog, the other, the GTKprint one.
...Akkana
Thanks, a very good idea. I'm building 5.2.0-beta4 and the closest I can find is src/gimp2/print.c , sadly I don't find anything that matches the snippet you posted. What function is it in?
thx.
gimp print dlg
Date: Wed, 10 Sep 2008 22:22:45 +0200 From: gg@catking.net
> ...Akkana
You don't need to do any of this any more; as of 5.0, the menu item is "Print with Gutenprint" (if GIMP 2.4 or above is in use) to distinguish it from the GTKPrint plugin bundled with GIMP.
gimp print dlg
It is the GtkPrint dialog. But the GIMP Print plug-in adds a notebook tab to it that provides the simple on screen scaling and positioning that you are looking for. What exactly is it that you are missing?
