Current status on migration
Current status on migration julien 05 Sep 20:48
  Current status on migration Ulf-D. Ehlert 06 Sep 21:08
   Current status on migration Ulf-D. Ehlert 07 Sep 11:26
    Current status on migration julien 08 Sep 08:24
     Current status on migration Ulf-D. Ehlert 08 Sep 13:56
      Current status on migration julien 09 Sep 21:37
julien
2008-09-05 20:48:32 UTC (almost 17 years ago)
Remember that it's work in progress, don't expect it to work without
any
problems.
We still have to find out when the script fails or when it produces files that we can't use.
I ran
xml2po-support> python tools/split-xml-multi-lang.py --debug -l fr -f oldsrc/menus/file-new.xml -d DEST
I got two directories, 'en' and 'fr' with file-new.xml in both. OK
I noticed in the 'fr' file: - in and , all language attributes are shown (lang=en;de;es...) even though there are fr para only.
- The tip is in english because it is not translated to 'fr'.
- In the grayscale section, there are 4 'en' para and 2 'fr' para in the source. In the destination 'fr' file, "missing" para are in english.
What is the use of the 'seqnum=' added?
Greetings,
Julien
Ulf-D. Ehlert
2008-09-06 21:08:48 UTC (almost 17 years ago)
Hi Julien,
julien (Freitag, 5. September 2008, 20:48):
I ran
Yes, 'xml2po' won't care about the "lang" attribute, so I didn't remove or replace them. And they may be useful for finding bugs:
English text
may be ok in a French XML file, but e.g.
English text
would obviously indicate a serious bug in our script.
Yes, that's intended. We need two XML files of the very same structure to use xml2po's "reuse" option. Try
xml2po --output=french.po --reuse=french.xml --language=fr english.xml
xml2po should replace any "translation" which is the same as the English source string with an empty string. (Check this!)
Hey, nobody is perfect. ;-)
What should the script do? Are the the missing 'fr' (and 'de') paras intentionally not translated? The 'en' paras may be added just yesterday, how can the script know?
But maybe it's a good idea to detect these cases and emit a warning.
They are internally used to mark a node as "seen". The current script version has been changed to remove these attributes when constructing the destination document.
Ulf
Ulf-D. Ehlert
2008-09-07 11:26:30 UTC (almost 17 years ago)
Ulf-D. Ehlert (Samstag, 6. September 2008, 21:08):
English text
s/de;fr/de/
Ulf
julien
2008-09-08 08:24:54 UTC (almost 17 years ago)
After updating xml2po-support, I ran: xml2po-support/DEST> xml2po --output=file-new.po --reuse fr/file-new.xml --language=fr en/file-new.xml
The file-new.po I got is wrong :-(. It is correct up to line 33, "Basic options".
From there, all msgstr are shifted:
#: en/file-new.xml:33(phrase)
msgid "Basic Options"
msgstr "Options de base"
#: en/file-new.xml:18(primary) en/file-new.xml:33(quote) msgid "New Image"
msgstr "Le dialogue d'une nouvelle image"
#: en/file-new.xml:33(phrase) en/file-new.xml:41(phrase) msgid "The dialog"
msgstr "Modèle"
#: en/file-new.xml:36(primary) en/file-new.xml:41(term) en/file-new.xml:42(quote)
msgid "Template"
msgstr "Menu" ####SHOULD BE Modèle
#: en/file-new.xml:36(secondary) msgid "Menu"
msgstr "Image" #SHOULD BE Menu
#: en/file-new.xml:17(primary) en/file-new.xml:38(primary) en/file-new.xml:94(primary) en/file-new.xml:171(primary) msgid "Image"
msgstr "Taille de l'image" ####SHOULD BE Image
#: en/file-new.xml:39(secondary) en/file-new.xml:41(primary) msgid "Image size"
msgstr "Lors de la création" ####SHOULD BE Taille de l'image
Further in the file, shifting is worse. there is no correspondence between msgid's and msgstr's.
This po in unusable. I would better write it by hand :-(
Greetings,
Julien
Ulf-D. Ehlert
2008-09-08 13:56:34 UTC (almost 17 years ago)
Hi Julien,
julien (Montag, 8. September 2008, 08:24):
Thanks for testing it. :-)
Yes, I can reproduce it.
My "file-new.po" contains the following output:
#: .../en/file-new.xml:33(phrase) .../en/file-new.xml:41(phrase) msgid "The dialog"
msgstr "Modèle"
Looking at the relevant lines of "en/file-new.xml" I find
33: ... The New Image dialog 42: ... The Template dialog
It seems that "xml2po" can't handle these lines when "reusing" an XML file even when original XML file and reused XML file both have the same structure.
However, I'm using my own patched version of "xml2po" - see
http://bugzilla.gnome.org/show_bug.cgi?id=545478
for the bugreport and
http://bugzilla.gnome.org/attachment.cgi?id=115553&action=view
for the patch.
Using the patched version of "xml2po" the output is usable. Some messages are not translated, but that's ok.
Apparently we can't rely on the default gnome-doc-utils package, looks like we have to provide a patched version of "xml2po". Hmm, maybe that's not so bad, then we could apply more patches, e.g. producing a useful header for our po files.
Ulf
julien
2008-09-09 21:37:53 UTC (almost 17 years ago)
for the patch.
Yes, I confirm :-)
Thank you for your work.
Julien
