gegl babl trouble
gegl babl trouble gg@catking.net 24 Aug 08:42
  gegl babl trouble David Gowers 24 Aug 15:53
  gegl babl trouble Sven Neumann 24 Aug 18:54
gg@catking.net
2008-08-24 08:42:13 UTC (over 16 years ago)
gegl babl trouble
I just pulled a clean svn gimp and wanted to build with --prefix=/usr/local , I supplied this arguement to autogen.sh and it output both that prefix and --prefix=/opt/gimp , which I presume is the new default.
I had the same behaviour from babl , although it did install where I requested
bash-3.2#ls /usr/local/lib babl-0.0 libbabl-0.0.la libbabl-0.0.so.0 pkgconfig fpc libbabl-0.0.so libbabl-0.0.so.0.23.0 X11
However, now I try to build gegl it can't find babl:
checking pkg-config is at least version 0.9.0... yes checking for BABL... configure: error: Package requirements (babl >= 0.0.22) were not met:
No package 'babl' found
Why can't it see a correctly installed babl? /usr/local/bin is in $PATH.
Thanks.
BTW INSTALL says to run ./configure which does not exist, should this be corrected to say autogen.sh ?
David Gowers
2008-08-24 15:53:44 UTC (over 16 years ago)
gegl babl trouble
... No. Something is wrong. Gimp does not specify any such thing. In fact, I always had the impression that for SVN versions, prefix defaulted to /usr/local.
This may actually be a problem with your autotools. I can verify that mine accept my chosen prefix (/usr) without saying anything more, I'm running
autoconf (GNU Autoconf) 2.61 automake 1.10 or 1.7 (yes, both.. normally programs use 1.10, some need 1.7)
on an installation of Ubuntu Hardy Heron.
What versions are you running (automake --version / autoconf --version) on what distribution?
Does the binary directory have anything to do with it? After all, babl installs no binaries, only libraries (ie /usr/local/lib/)
configure exists for releases -- it's generated by autogen.sh. This is normal for autotools-based software building.
Hope that helped, David
2008-08-24 18:54:40 UTC (over 16 years ago)
gegl babl trouble
Definitely not. The default prefix is, and has always been, /usr/local.
Have you adjusted PKG_CONFIG_PATH ?
INSTALL has the instructions for building from a tarball. When building from SVN some extra steps are necessary.
If you have build problems, perhaps it would be a good idea to use the babl and GEGL release tarballs instead of SVN checkouts.
