GIMPHints blog
GIMPHints blog Roman Joost 25 Jul 20:46
Roman Joost
2008-07-25 20:46:39 UTC (over 17 years ago)
GIMPHints blog
Peter had a nice idea today: We start collecting tips similar to the GIMP Ui brainstorm blog.
People send new hints to us, we're putting them on the blog. The best tips make it in the application. The only thing we've to think about is
a central E-Mail address (probably something of gimphints at googlemail.com, where every moderator get's access, or the mail is forwarded to the moderators)
the rules (I started already thinking about them, I guess the only rule missing is the copyright. If we want to use the tips in the application or manual, Authors should be aware that they're publishing under the GFDL or a similar license).
I started the blog at:
http://gimphints.blogspot.com/
and I need your login names to put you as a moderator on the blog.
Cheers,
