no make for color-management.xml
10 of 10 messages available
no make for color-management.xml Kolbjørn Stuestøl 08 Jul 23:22
  no make for color-management.xml Roman Joost 09 Jul 10:26
   no make for color-management.xml Sven Neumann 10 Jul 08:31
   no make for color-management.xml Kolbjørn Stuestøl 11 Jul 13:04
    no make for color-management.xml Roman Joost 13 Jul 14:23
     no make for color-management.xml Kolbjørn Stuestøl 14 Jul 22:52
      no make for color-management.xml Kolbjørn Stuestøl 15 Jul 22:44
       no make for color-management.xml Ulf-D. Ehlert 16 Jul 12:43
       no make for color-management.xml Ulf-D. Ehlert 16 Jul 21:02
        no make for color-management.xml Kolbjørn Stuestøl 17 Jul 00:34
Kolbjørn Stuestøl
2008-07-08 23:22:09 UTC (almost 17 years ago)
When running 'make' (make ALL_LINGUAS="no") the file "concepts/color-management.xml" is not found. No HTML code generated for 'no' from this file. I have checked for the "normal" errors such as missing lang tags etc. (Copy: '
Moreover: When running "svn diff" all my changes are recognized, also those in the "color-management.xml". The only exception is that instead of the usual error message generated from the revision tag when running "patch -p0..." ("Hunk #2 FAILED at 36") I now get "Hunk #2 succeeded at 36 with fuzz 2".
Running make ALL_LINGUAS="en de" makes the HTML, including color management. (Have not tried other languages).
I do have run "autogen.sh" with the latest updatings and "make clean" and also have checked for unwanted line feeds etc.(but you never knows...). Even tried the Windows solution to all problems: restart and the Linux equivalent: reload ;-)
I'm using Notepad++ and Cygwin.
Perhaps one of the unexplainable errors? Any suggestions?
Kolbj?rn Stuest?l
Roman Joost
2008-07-09 10:26:15 UTC (almost 17 years ago)
Hi Kolbj?rn,
Actually, you always want to compile the HTML files including English:
make ALL_LINGUAS="en no"
because English is the current fallback language if no translation for Norwegian exist.
I just tested and got no error.
Hm... everything up to date? Do a 'svn up' to verify that ...
Greetings,
2008-07-10 08:31:20 UTC (almost 17 years ago)
That doesn't matter for a translator, right? And users should be using the releases with pre-compiled HTML files anyway.
Kolbjørn Stuestøl
2008-07-11 13:04:18 UTC (almost 17 years ago)
Roman Joost skreiv:
Hi Kolbj?rn,
Thank you Roman for giving a try. Yes, I tried both svn update and svn checkout after deleting the file "color-management.xml".
As "svn diff" recognized the difference, it probably is a problem in the make part of the program. Looks like "make validate" do not see or recognize the 'no' in the lang tag. As an experiment I added the missing 'no' tags by hand directly to the xml/no.xml file generated by the "make", and thereafter run make ALL_LINGUAS="no" and got the missing HTML codes. But that's not the solution ;-)
Someone who knows what "make" are looking for (other than the lang tags) when generating the HTML? I do not know a way to trace or step the running of any command in Cygwin. Someone knows? When I started translating there was a problem somewhere as the program read the lang tag 'no' as no (opposite of yes) but I do not think this is the problem now as all other files as far as I know are recognized. Should be happy to find another file not translated to Norwegian to give it a try.
At the moment I do not add the Norwegian translation of the color-management.xml file and comment out the links to this file. But am still trying to find a solution.
Kolbj?rn
Greetings,
Roman Joost
2008-07-13 14:23:05 UTC (almost 17 years ago)
Hi Kolbj?rn,
That's weird, because IMHO there is no no.xml create if make validate fails ...
Actually make does not look for "something", the only command it's executing is:
xsltproc --xinclude --stringparam profile.lang no stylesheets/profile.xsl xml/no.xml
to profile the XML into Norwegian only DocBook/XML.
I still don't really get were to look for and still tapping in the dark ...
Greetings,
Kolbjørn Stuestøl
2008-07-14 22:52:48 UTC (almost 17 years ago)
Roman Joost skreiv:
Hi Kolbj?rn,
I'll have to check this out. Where did the no.xml come from?
I'll check this out.
Neither do I, but I'll give it a try. Thank you for the tips. I have to work further on the problem I think. Kolbj?rn
Greetings,
Kolbjørn Stuestøl
2008-07-15 22:44:13 UTC (almost 17 years ago)
Roman Joost skreiv:
Hi Kolbj?rn,
I have boiled it down a bit:
The problem seems to be either in the 'make validate' command or in the file "color-management.xml". Most reasonable the last one? The command "make validate" creates the no.xml file consisting of all the 'no' tags from all the xml files *except* from the file "color-management.xml".
I was lucky to find another file (filters/alpha-to-logo/3d-outline.xml) not translated to Norwegian. The 'make validate' found the 'no' tags in this file too.
It looks like "color-management.xml" is the only file not recognized. Therefore my working theory (at the time of writing this) is that somewhere in this file there are some code/letter combinations telling the command 'validate' to skip this file? Now I have to figure out how to verify this theory. Copying the heading down to '' from a different, working file to the 'corrupted' file and deleting the 'section history' part of the file did not 'cure' the file. Perhaps there is another explanation? Perhaps it's my computer? In this world you never knows...
I know too little, and have not the equipment, to step trough the validate command by hand. Otherwise that would be a way to figure out what happens. If someone would like to experiment with the file, it is here: http://home.online.no/~kol-stue/temp/color-management.zip
By the way: One of my tests was running 'check_lang_attributes.pl'. It returned no errors.
I also run 'make clean' before every attempt.
(Sometimes the impossible needs more time to be solved ;-) ) Kolbj?rn
Ulf-D. Ehlert
2008-07-16 12:43:03 UTC (almost 17 years ago)
Hi Kolbj?rn,
Kolbj?rn Stuest?l (Dienstag, 15. Juli 2008, 22:44):
If you are working with current unchanged version (after "svn update"), you can't get the Norwegian translation since the "lang" attributes of these files don't contain "no".
If you are trying to make HTML with an edited version of "color-management.xml", try "svn diff" and check the output carefully. Most likely you forgot to enable "no".
If everything seems to be all right, check it once more! ;-)
"make validate" doesn't care about lang attributes.
No.
This script just checks for the common bugs like lang="en:no" (missing semicolon).
Bye,
Ulf
Ulf-D. Ehlert
2008-07-16 21:02:37 UTC (almost 17 years ago)
Hi Kolbj?rn,
This file seems to be ok, but do you really include it? Did you edit src/gimp.xml:
Color Management with GIMP
Farbmanagement mit GIMP
Gestion de la couleur avec GIMP Gestione del colore con GIMP
Bye,
Ulf
-------------- next part -------------- A non-text attachment was scrubbed... Name: not available
Desc: not available
Url : /lists/gimp-docs/attachments/20080716/0064fd96/attachment.bin
Kolbjørn Stuestøl
2008-07-17 00:34:48 UTC (almost 17 years ago)
Ulf-D. Ehlert skreiv:
Hi Kolbj?rn,
Yes, I found out but had problems connecting to the internet this evening to let you know.
So the problem is solved :-)
I had forgotten to adding the 'no' code you mentioned above. :-[
I apologize for waisting your time just because of my lack of knowledge and thank you to you and Roman for helping me. Sometimes I do not see the forest because of all the trees. With regards from
Kolbj?rn
Bye,
Ulf
