GIMP help in 2.6
8 of 8 messages available
GIMP help in 2.6 Sven Neumann 01 Jul 23:25
  GIMP help in 2.6 Ulf-D. Ehlert 02 Jul 21:25
   GIMP help in 2.6 Sven Neumann 04 Jul 08:59
    GIMP help in 2.6 Sven Neumann 05 Jul 13:18
     GIMP help in 2.6 Roman Joost 05 Jul 18:11
      GIMP help in 2.6 Sven Neumann 06 Jul 03:22
      GIMP help in 2.6 Sven Neumann 07 Jul 08:56
  GIMP help in 2.6 Roman Joost 03 Jul 08:37
2008-07-01 23:25:31 UTC (almost 17 years ago)
GIMP help in 2.6
I'd like to point out some changes and new features in GIMP 2.5.1 affecting the GIMP help system. I'd love if some of you guys could give it some testing and give feedback.
?The help browser has been ported from gtkhtml2 to WebKit. It now does a much better job at rendering the user manual. While doing the port, I have also streamlined the user interface further and the help browser is now even more compact and hopefully easier to use.
The user manual can now be used online. There's an option in the Preferences dialog for this. When selected, the user does not need to install the gimp-help package and the context help will access the online user manual directly. The plan for GIMP 2.6 is to make this even easier and to ask the user if the online version should be used when she tries to access the help for the first time and no local copy of the user manual is installed.
I hope you will like these changes.
Ulf-D. Ehlert
2008-07-02 21:25:23 UTC (almost 17 years ago)
GIMP help in 2.6
Sven Neumann (Dienstag, 1. Juli 2008, 23:25):
Is this WebKit from http://webkit.org/?
It looks like they don't provide stable packages, and I don't have the time (and probably knowledge) to fix their bugs.
Is there any other source? If not, is it possible to compile gimp without WebKit (or without gimp-help-browser if necessary)?
Ulf
Roman Joost
2008-07-03 08:37:37 UTC (almost 17 years ago)
GIMP help in 2.6
Hi Sven,
I very much like this feature and I think it will help users as well skipping the part of installing the manual and fetch it over the net as well (if they have a permanent connection).
Thanks for your work!
2008-07-04 08:59:37 UTC (almost 17 years ago)
GIMP help in 2.6
Yes, the GTK+ port of this browser engine.
A stable webkit release (1.0) is supposed to be available very soon now.
That's what happens automatically if webkit is not installed.
2008-07-05 13:18:12 UTC (almost 17 years ago)
GIMP help in 2.6
It even has been released while I was on vacation. The 1.0.1 release is available from
http://people.freedesktop.org/~alp/webkit/gtk/webkit-1.0.1.tar.gz
Roman Joost
2008-07-05 18:11:57 UTC (almost 17 years ago)
GIMP help in 2.6
Hi Sven,
I couldn't resist trying it out. Installed webkit and now my help browser works again - yay!
I tried the preferences switch so the help browser loads the manual from the internet and run into a problem. When pressing F1 I get an error message:
There is a problem with the GIMP user manual.
Could not open 'http://docs.gimp.org/en/gimp-help.xml' for reading: Operation not supported
Please check your installation
I checked with mozilla and the path is correct. Do I need to setup a GIMP2_HELP_URI again or something? I run GIMP with --verbose and got the following information:
HELP: request for help-id '(null)' from help-domain '(null)'
If it's a bug I file a report.
Cheers,
2008-07-06 03:22:14 UTC (almost 17 years ago)
GIMP help in 2.6
Looks like you don't have gvfs installed. Unfortunately there's no way to check that at compile time. It should be considered a dependency for gio.
2008-07-07 08:56:39 UTC (almost 17 years ago)
GIMP help in 2.6
You should get a slightly more useful error message now. But I am still puzzled why your installation of GIO/GVFS doesn't handle http: requests. I will get a new computer at work this week and it will run Ubuntu Hardy. I will check if I can reproduce the problem there.
In the meantime I have also added a check for the local user manual installation. So if a user requests help and the manual is not installed, she will see a dialog asking if she wants to use the online version instead.
