Some notices...
Some notices... Alessandro Falappa 27 Mar 11:17
  Some notices... Ulf-D. Ehlert 29 Mar 19:11
   Some notices... Alessandro Falappa 31 Mar 10:40
Alessandro Falappa
2008-03-27 11:17:49 UTC (about 17 years ago)
Some notices...
Hello all,
I would kindly ask you to review the newly added 'en' documentation of the Engrave distort filter contributed by me and recently committed by Marco Ciampa.
I would also take the opportunity to point out that in the README file a validation procedure using a lint target of the makefile is wrong. This may be an old way of doing things superseded by the new validate target.
I would suggest to document the new useful 'make draft' procedure instead.
Cheers.
Ulf-D. Ehlert
2008-03-29 19:11:48 UTC (about 17 years ago)
Some notices...
Hi Alessandro ,
Alessandro Falappa (Donnerstag, 27. M?rz 2008, 11:17): [...]
Thanks, I changed the README file according to your suggestions. [*]
Please note that I added one more item to the "Hints for making good screenshots":
"before saving an image as PNG, check if you can convert it to indexed mode without loss of quality (saves space and bandwidth)"
And I changed the 'make draft' procedure a little bit: Now the name of the HTML output file is html/LANG/-draft.html
(with "-draft" added). This way you will never overwrite an original HTML file. ('make' will always tell you the name of the output file.)
Ulf
[*] BTW, nobody would have killed you if you had corrected it yourself. ;-)
Alessandro Falappa
2008-03-31 10:40:18 UTC (about 17 years ago)
Some notices...
Hello Ulf,
Ulf-D. Ehlert ha scritto:
Hi Alessandro ,
Glad to hear that.
Good hint, I have to check the images I am producing for the lens distortion filter...
Ulf
That was my intention, but you were faster than me!
Cheers
