keyboard reference card ?
keyboard reference card ? Sven Neumann 24 Mar 18:21
  keyboard reference card ? Marco Ciampa 25 Mar 00:46
   keyboard reference card ? Roman Joost 25 Mar 11:29
  keyboard reference card ? Roman Joost 25 Mar 07:16
2008-03-24 18:21:19 UTC (almost 17 years ago)
what happened to the GIMP keyboard shortcuts reference card that was supposed to be distributed with the GIMP user manual? At some point we removed this from the GIMP source tree because it was supposed to be included with the user manual. But I haven't been able to locate it there. And others are now duplicating this effort:
http://www.gimpusers.com/gimp-hotkeys.php
Marco Ciampa
2008-03-25 00:46:40 UTC (almost 17 years ago)
and what about the key and mouse reference in the manual? Is there any reason for which it is not translatable?
bye
Roman Joost
2008-03-25 07:16:24 UTC (almost 17 years ago)
Hi Sven,
It's downloadable as a PDF from:
http://docs.gimp.org/download.html
and you can find the source in the quickreference subfolder of the gimp-help-2 module.
Greetings,
Roman Joost
2008-03-25 11:29:54 UTC (almost 17 years ago)
The DocBook integration is currently missing, with the automatically generated quickreference in the 'quickreference' subfolder. It creates for every language a DocBook XML file, but our manual uses DocBook XML with merged translations.
So, either we link to every translated, autogenerated quickreference file or the stylesheets which create the DocBook output for the quickreference must be revamped.
Greetings,
